A-Pillar removal
A-Pillar trim panel removal
Has anyone removed A-Pillar trim panels to replace tweeters? I thought they would just pop out, but something is holding them at the bottom. Replaced the door and rear deck speakers and this is the final piece of the upgrade project.
Kicker KS654s front/rear. Stage 3 Motorsports has a video for door/rear deck speaker replacement
. The tweeter required a Dremel tool to open the hole larger to fit the speakers. The factory plastic bracket needs to be cut out first. everything is a soft nylon so it is easy to work with. Since the new tweeter retaining ring cannot fit in the angular pillar trim, I opened the hole just large enough to press the threaded tweeter body in, with effort. They do not move, but with effort they can be removed or rotated to position the 'K' logo. Be sure to use the crossover that comes with them. They put the factory units to shame.
