Upgrade Help
Upgrade Help
I have a 2011 GT/CS daily driver with the below mods.
Long Tube Headers
Cold Air Intake
373 Gears
Suspension upgrade (can’t remember name)
HP Tune
i will start off saying I am a not a gear head. I am looking at upgrading the items below. I was just curious on thoughts or if I might be missing something.
Intake
Throttle body
Injector
Fuel Rails? (Not sure if this would be needed or not)
Again I am learning, so any constructive advice is appreciated. Thank you.
Long Tube Headers
Cold Air Intake
373 Gears
HP Tune
Intake
Throttle body
Injector
From what you describe, I'm assuming your referring to upgrading the stock intake manifold to something like the Boss 302 manifold? You already have a cold air intake listed as one of your current mods, therefore I don't believe your looking to upgrade the cold air intake.. As for upgrading to larger throttle body, injectors and fuel rails, If your looking to gain as much HP/TQ as possible by increasing airflow with a larger intake manifold and throttle body? then yes, your also going to need to increase the amount of fuel as well in order to take full advantage of the increase in airflow.. Also keep in mind that a tune revision may be required for the larger intake manifold, fuel injectors and possibly the larger throttle body as well
That being said, you might also consider looking into adding the Kenne Bell Boost-A-Pump as well.. Meanwhile, hope you find the info provided as useful.
https://lmr.com/item/KB-89069/Kenne-...p-Single-40amp
Hi, I'm also new to this. At the service station, I was advised to install f150 ecoboost mods. This is a cool thing. Fuel economy can be adjusted with a tuner, a small device that connects to your car and allows you to change hidden settings. ordered here https://boostyourengine.com/f150-ecoboost-mods/. Now you can economically get to your favorite places and admire the sunset
