Suspension
Suspension
My 2014 Mustang GT CS was lowered by the previous owner and with that, he installed Eibach shocks or struts. Is there a better strut then Eibach? Ride in my stang is good but compared to my winter driver there is much room for improvement. Any suggestions welcome.
what kind of improvement are you looking for?
basically; do you want to be more isolated from the road with a generally softer ride, with the suspension absorbing more of the bumps so you don't feel them; or do you want to be more connected to the road, with a firmer ride, meaning you will feel more of the bumps but body movement/roll will be reduced and "handling" improved?
I'm not taking the car to the track or racing it and so I'd like a smoother ride. It feels like it bottoms out sometimes hitting bumps,I'm looking for a smoother/softer ride. Handling is not important either.
Lowering generally causes two main compromises in the ride:
1) less suspension travel means more likely to bottom-out
2) stiffer spring rates used, to firm-up the handling and compensate for the tendency to bottom out
Also, my understanding is that the Eibach springs (and maybe shocks/struts) are performance oriented and generally have high spring rates, meaning relatively stiff ride (they have a few different springs available so this depends on which ones you have). Also when lowering, the bump stops should be trimmed to allow a little more travel; if this was not done then that could contribute to the feeling of bottoming out.
Low profile tires also contribute to the feeling of hard ride -- don't know what you have, but if you have 20" wheels (or 19" with 3- or 35 aspect ratio tires) that could be part of it
I'm thinking you might want to go back to OEM struts/shocks/springs; or maybe the OEM springs on a "better" strut/shock such as Bilstein
You could look for "take-off" OEM struts/shocks/springs, which are usually available cheap from people who took them off when they lowered their car -- check E-bay or local Craig's List if that sounds interesting
