2011 - 2014 GT/CS Special Section for the California Special owners.
Hellion Twin Turbo Project
Old Jan 4, 2014 | 03:52 PM
  #41
figit's Avatar
Your attention to detail throughout the entire build has been heroic, thanks again for documenting the build. Would you say all in, with the additional quality control and peace of mind measures you've taken, one would be looking at 10 to 11k for the same setup before labor? I know it's in bad taste to ask such a question, as I mentioned before I've been considering this route for awhile and I'd also want to take extra precautions to make sure once completed, it's as buttoned up as possible so I'm wondering in the end what I'm looking at cost wise. Thanks again!
Old Jan 4, 2014 | 06:18 PM
  #42
Onelildude's Avatar
Awesome build and great looking car. Thanks for sharing
Old Jan 4, 2014 | 08:50 PM
  #43
cal dreamn's Avatar
Tt Helios
Absolute awesome build!! Thx for sharing
Old Jan 5, 2014 | 05:49 PM
  #44
04sleeper's Avatar
$11K would get you in the ballpark with what I have done. $8K for Turbo kit + Blankets etc... $2K for fuel system. $900 for injectors. $100 for misc stuff. Maybe a few hundred more for the catch can set up. Also add in exhaust midpipe and cat back if you would like to add that. Not necessary though. I did save a lot by doing all the labor myself.
Thank you.
Any time.
Old Dec 31, 2015 | 09:05 AM
  #45
04sleeper's Avatar
Figured I would give an update. Car is running Great! I am extremely happy with how the car has performed and how well the kit is made.
Here is another quick video I made with a different mic mount.
Old Dec 30, 2017 | 08:06 AM
  #46
04sleeper's Avatar
End of 2017 Update. Finally had a chance to dyno the car. Set the boost controller to 10 psi and went to 6800 RPM's or so.
Old Dec 30, 2017 | 08:07 AM
  #47
04sleeper's Avatar
Time to pull the motor while it's still in one piece and swap in an Aluminator and turn the boost up! Stay tuned.
Old Dec 30, 2017 | 09:52 AM
  #48
SpectreH's Avatar
Impressive numbers! Good idea to swap out now while the current engine is still good.
Old Dec 24, 2018 | 07:50 AM
  #49
04sleeper's Avatar
Ok. Update. Ended up going with a Gen2 Aluminator and had to swap intake cams and timing components from a 2011-2014 because they are different. Also added a billet cam gear to go along with the billet oil pump gear that came with the engine. Also upgraded the trans throughout. (Stage 2 clutches, Billet Intermediate Shaft, Upgraded bearing supports, etc.
Made some pulls based on my boost settings. Order goes 6.5 psi (Gate Pressure) 9.5 psi, 11.2 psi, 14.5 psi and 19 psi.
Old Dec 24, 2018 | 11:31 AM
  #50
Wow that's a lot of ponies!
Old Dec 27, 2018 | 09:04 AM
  #51
Bert's Avatar
yowsa wowsa indeed!
I hope it holds together long enough to get a few runs on the strip . . . hopefully a lot longer than that, it sounds like you really built it right
Old Jan 1, 2019 | 08:20 AM
  #52
04sleeper's Avatar
Thanks.
Originally Posted by Bert
yowsa wowsa indeed!
It should. It has all the right parts. I will most likely keep it in the 850-900 range to keep it happy.
Plan is to get to the track once it opens and see if I can crack 9's on the 20" wheels leaving off the foot brake.
dmichaels
Sep 11, 2016 08:12 AM
Zastava_101
Dec 21, 2011 12:37 PM
GONE_N_60
Oct 29, 2009 11:48 AM
