Tire and Wheel Tech All the tire and wheel technical information you can think of in one place!
Widest tire on 9" wheel safely?
Old Apr 17, 2015 | 07:59 AM
TripleBlack14's Avatar
I'm presently running stock 245/45/19 with 9" wheels.
I'm thinking about a different set of 9" wheels, and replace the tires at a later date with wider rubber. It'll be a square set-up.
It looks like a 275/40/19 would give me 1.2" more tire patch to the ground and the tire height is identical. Would a this be safe for 9" wheels?
Can I go as high as a 285/40/19?
Safety is primary.
Old Apr 17, 2015 | 09:19 AM
DarrenGT's Avatar
Safety is primary.
in my unedumacated opinion you do not want to go that big up front. it doesn't add any 'safety' but will affect steering and produce unnecessary stress on the front end. if it will even fit on the front. 285's out back on 10" rims are what i currently run with 255's up front. i've seen max 275's up front on 9" rims.
Old Apr 17, 2015 | 09:22 AM
Thanks Darren. I'm still toying with the idea of new wheels, but tires will wait. Just planning ahead, but if I can run 275/40/19 square safely I'd consider staying with 9" wheels. I'd like a bit more patch on the asphalt.
Old Apr 17, 2015 | 05:02 PM
ElkGroveFordGuy's Avatar
I run 275/40/19 tires on a 19x9.5 rims!
Fit perfect work great!
Old Apr 17, 2015 | 06:05 PM
But I wonder how much difference your extra .5" makes. 275/40 seem ideal if I can feel safe on 9" rims.
As an aside, my ex-wife demanded 9". I told her I wasn't cutting off 2" for anybody.
Old Apr 17, 2015 | 09:32 PM
Enfynet's Avatar
I've seen people put 285s on the back, but typically 255-265 is the widest you'll see on 9" rims up front. 275s fit up front, but I wouldn't want to risk it on a 9" wheel.
Old Apr 17, 2015 | 10:49 PM
Many guys are autocross racing on the factory 9" wide brembo wheels with a 275 wide tire, front and rear!
Old Apr 18, 2015 | 12:35 AM
Ford and GM put 275/40/17s on the 99-04 Cobras and 94-03 F-Bodies, stock. 275/40/19s are what I'm going with when I replace the daily tires. 275/35/19 would be the same overall diameter as the 255/40/19s, but I want a little taller sidewall for better ride and to fill the wheel wells without actually lowering the car more.
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
