Tire and Wheel Tech All the tire and wheel technical information you can think of in one place!
Need help with offset
Old Feb 22, 2019 | 04:36 PM
Skylar's Avatar
I'm planning on ordering wheels for my '15 ecoboost and I'm not sure which offset I need to have them flush with the fenders all the way around. Here's my options:
19x9.5 w/ 35 offset
19x9.5 w/ 22 offset
19x10.5 w/ 22 offset
I don't have the performance pack so I shouldn't have to worry about clearing the brakes. Also, I'm loweres 1" on SR springs.
Opinions on which setup to go with? I think I would prefer 9.5" but what's everyone think?
Thanks!
Old Feb 22, 2019 | 08:57 PM
Skylar's Avatar
bump
Old Feb 22, 2019 | 09:49 PM
Gabe's Avatar
The 19x9.5 with 35mm offset should fit great.
The others, especially the 10.5 will poke out beyond the fender.
Old Feb 22, 2019 | 09:54 PM
Skylar's Avatar
There is also a 20 x 10.5 w/ 30 offset. Opinions?
Old Feb 22, 2019 | 10:04 PM
Gabe's Avatar
Just about as bad.
You need to look for offset in the 40+ mm range if a 10"+ rear wheel is used.
On my '13 a 20x10 with 48mm offset and a 305/35/20 rear tire fit perfectly inside the fender.
On the '15+ body you can get away with a few less mm offset, but not 15-20, so try to stay around 45mm offset if looking at 10.5" width.
Old Feb 22, 2019 | 10:34 PM
Skylar's Avatar
Just about as bad.
These are 20x10.5 w/ 30 offset and they don't seem to poke too bad. I'm wanting 20" to close my fender gap a little. That little bit of poke is worth it to close the wheel gap I think
​https://www.instagram.com/p/BsoXUIYFiLP/?utm_source=ig_share_sheet&igshid=1eyjd6dgnarp4
firstang001
Dec 4, 2015 11:32 AM
vc4life
'10-14 Exterior Modifications
Aug 19, 2011 09:12 AM
chuckieduck
05-09 Exterior Modifications
Oct 5, 2008 11:05 AM
ohavemercy
Apr 21, 2006 08:54 PM
seaclam
Jan 4, 2006 08:47 PM
