The whole shabang !!!!
The Whole Shebang !!!!
Koni Yellow Adjustable Sruts and shocks, Steeda Sport springs and Steeda Heavy duty strut mount /w camber adjustment, Stranoparts 1 3/8in adjustable hollow Front sway, Steeda's Front Swaybar Mount Brace Kit, Helwig 1 in adjustable solid rear sway bar, UMI subframe connectors, Steeda LCA relocation bracets, BMR Panhard Rod, DOM, On-car Adjustable, Polyurethane Bushings (not the bar showing in pic)
Haha say goodbye to low nvh, but hello to a ****load of fun.
I'm going to do some subframe work to my 14 soon. The chassis may be improved, but it's still a bit noodley for my taste.
I'm sure it does.
However, it does a noticeably better job with an aftermarket panhard brace, even with all of the other equipment installed; I know this from personal experience. Go here, and read the newest review:
http://www.americanmuscle.com/whitel...eviews-section
(Note: I am not employed by AM or Whiteline, nor necessarily advocating their products.)
I'm sure it does.
I'm sure it does.
Ae you the same Gear Poet from Miata.net? If so, good to see you here!
