Watts link axle brackets dont make good bump stops.
Old Apr 13, 2015 | 05:18 PM
ConeBoss's Avatar
Hey All,
Figured I would share a quick piece of experience I had recently. Went to a 2.5in spring courtesy of UPR custom spring perches. This resulted in a couple things.
First the ability to corner balance the car without a true coil over.(awesome)
Second, about 1/4in drop in rear of car.(awesome...mostly)
The second change had an unexpected and unfortunate side effect. My axle brackets for my Steeda watts link were now acting like bump stops...not awesome.
My car is not slammed by any stretch of the imagination and raising the car back up is not something I want to do to accommodate the watts link.
Something to keep in mind when folks are shopping for a watts link. You may want to just go with the type that replaces the Diff cover if you have a pretty low car and don't want to change the ride height.
Old Apr 13, 2015 | 09:41 PM
Stevedotmil's Avatar
Good to know. Thanks for the update to your suspension. I have been following your car for a while in here. I wish BMR would get theirs done so I could buy that one. It's supposed to be the best between the Fays2, Whiteline, and Steeda units.
Old Apr 14, 2015 | 05:52 PM
David Young's Avatar
I went through the same thing with my Steeda watts link. I had to loosen the drivers side axle clamp and move it toward the center pumpkin around 1/2 inch or so, to clear the head of the bolt. Works perfect now
Old Apr 15, 2015 | 02:55 PM
ConeBoss's Avatar
Stevedotmil - Check out the offering from Cortex racing.
Old Apr 15, 2015 | 05:04 PM
5.M0NSTER's Avatar
Hey, good info. Thanks for sharing
So what's the plan to fix it? Can you get taller bump stops to cushion the blow?
Old Apr 30, 2015 | 03:26 PM
ConeBoss's Avatar
Removed Steeda Watts link unit and replaced with a cortex racing version that replaces diff. cover. Problem solved.
...anyone want to buy a used Steed Watts link set up?
Old May 1, 2015 | 12:39 PM
13GetThere's Avatar
So how many adjustments do you have for the pivot point on the diff. cover of the cortex, and are you using shocks and springs or coil overs?
Old May 5, 2015 | 02:30 PM
ConeBoss's Avatar
You get 4 different adjustment points on the Diff. cover. Shock + spring.
ssjbuu
Aug 28, 2015 08:55 AM
glo106
Aug 11, 2015 08:29 AM
killaz05
Jul 24, 2015 08:49 AM
Kgilly
Jul 9, 2015 01:47 PM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
