Tire suggestion
Old Aug 14, 2015 | 12:47 AM
14BlackGT's Avatar
Tire suggestion
Hi all.
I have the black machined stock wheels 19x8.5 with 245/45-19 tires.
There is an aftermarket wheel that is the same but is 19x10. What tire size do you recommend? 275/40? Any suggestions for a wider tire size?
This is what they look like.
http://www.ebay.com/itm/391093489080?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Sorry if this is some other thread. I looked. Thanks!
Old Aug 14, 2015 | 05:11 AM
TripleBlack14's Avatar
Originally Posted by 14BlackGT
Hi all.
19" Black Machined Mustang Style Wheel 19x10 Rim Fits Ford | eBay
Foose Outcasts are very close, but as far as I can tell they're only available in 20".
http://www.americanmuscle.com/machin...cast-2015.html
Old Aug 22, 2015 | 01:22 AM
Trumpetlon's Avatar
275/40 will match the overall height with the 245/45. 285/35 will be .75 or so shorter but if you replace your fronts with 255/40 they will be approximately the same height.
Old Aug 22, 2015 | 01:52 PM
5.M0NSTER's Avatar
I agree with Lon. 275/40 if you want taller sidewall, or 285/35 if you want more grip and stiffer sidewall.
Old Aug 25, 2015 | 03:25 PM
14BlackGT's Avatar
Thanks everybody!
Old Aug 25, 2015 | 05:57 PM
Tire suggestion
Also you should know your stock center caps won't fit, and the finish won't be 100% exact to the stock wheels. If you like them, just get the full set...
Old Aug 26, 2015 | 12:33 PM
14BlackGT's Avatar
Thanks! I'll just leave well enough alone and it will save me around $900. I wanted a close if not exact match so I won't be getting them.
robjh22
Sep 23, 2015 07:03 AM
oldnjguy
Sep 10, 2015 02:39 PM
Sep 8, 2015 10:45 AM
