SR Springs Install Options???
Anyone know what size nuts I'm going to need for the Koni STR.T's to put them in my car when I do the drop? Also wondering how much I should cut the factory bump stops, since I didn't order any? I really want this to go smoothly, considering I keep finding out that I need something else every time I turn around. At least now I will be able to build up the front struts with springs mounts and hardware before I ever loosen the first bolt on the car.
Lee
Lee
They come with the nuts already. You're correct on the length of the struts, they're a "little" shorter which allows for more travel. Anyone wanting to lower they're car and run a great damper set and in a cost bracket of 700 or less the Koni yellows and STR.T's are really the way to go.
