Questions regarding LCA brackets
I currently have the FRPP K springs on my 2011 GT and I am about to upgrade my suspension. I am about to purchase an adjustable UCA, adjustable panhard bar, LCAs, and camber bolts.
Would I need to purchase LCA relocation brackets even though my UCA is adjustable? Would I be able to correct/tune my pinion angle off of the adjustable UCA alone?
Any insight would help a lot! Thanks!
You will likely still need the LCA relocation brackets to correct the angle of your LCAs, which cannot be corrected by an adjustable UCA. The adjustable UCA will allow you to correct the pinion angle, assuming you will be buying fixed length LCAs.
I put them on my car because I wanted to do everything "right." I don't think it makes enough difference that I would do it again unless I felt I lost something after lowering. Many folks here say it isn't needed with minor lowering. I tend to agree.
Dropped my car an inch and still did them, correct LCA placement, from what I have read, has the LCA pointing slightly towards the ground. Stock placement is pretty much parallel to the axle, and after lowered it is slightly higher then the axle, so I would say they are required unless you want wheel hop.
