P's on a V6
Old Nov 23, 2013 | 07:41 PM
cnp0079's Avatar
P's on a V6
Hey All,
I'm looking to track a V6 on the road courses.
The FRPP P springs are cheap. Will those fit on a V6? the info says 1" drop. if the cars already have a 'rake' then the lighter V6 may make it level. say 0.75" drop in front 1" in rear.
sound good?
wonder if these would work w/ Koni SRTs or Bilsteins.
Guessing I can run these w/ my factory strut mounts if I'm careful in disassembling everything.
Old Nov 25, 2013 | 05:21 AM
Brandon302's Avatar
It will most likely get rid of some of your rake but shouldn't completely level the car out. You can run them with the stock shocks but they may be underdampened so you might wear them out more quickly. You would probably want to get better shocks anyway if you are going to track the car, why not Yellows or something adjustable so that should you want to change the rebound you can? And yes you can reuse the stock mounts if you are careful, only reason/way you could switch to the GT500 mounts is if you bought the 05-10 specific shocks.
