Need suggestions on wheel and offset
Hi Friends! I am planning to get Ambit RE02 wheels. I would like them in 18 inch, as that is the max size these come in. I would like to get a deep concave setup. so wondering if I can go with 18X9.5 +15 in the front and 18X10.5 +15 in the rear?
I am not a genius with offset thing
And, I am assuming that lesser the offset more concave it is.. I would really appreciate your input
. Thank you
. Thank you
No. They will stick out inches beyond the fenders. The fronts you MIGHT be able to get to fit, with stretched tires and -4.0 degrees of camber. The rears will literally stick out 2" past the fender.
You might be able to run the +22 18x9.5s all around...you won't be able to go very low on your suspension though. I was running 20x10.5 +40 on 305/30/20 and they rubbed. I'm on H&R Supersports (Sportline equivalent). I switched to 275/35s and no more running. These wheels are already past the edge by almost 1/2". If you went 10.5 +15, you're adding another 1".
Also in my research i found this link. Just for reference. Notice the wheel specs in the post.
Those tires are stretched. Not to mention I guarantee it rubs in the back. That or he's running insanely stiff springs to keep the tires off the fenders. You can roll and or flare the stock fenders a bit more than they come from the factory, but I don't see how those tires aren't tearing up the fenders, at least from my experience.
PonyMuscletang13
26
Apr 4, 2016 08:08 PM
C Moe
Mar 16, 2016 08:52 PM
