Help please!
Old Feb 24, 2012 | 03:15 PM
06blackvertstang's Avatar
Help please!
I'm very new to all of this suspension stuff but I'm learning so dont grille me. My question is can I put lowering springs on my car as a do it yourself project? I've heard you have to have a spring compressor?
Old Feb 24, 2012 | 05:47 PM
corruptor's Avatar
Yes, you can DIY if you rent a spring compressor from a local hardware/auto parts store. The spring compressors are really just clamps that hold the spring in place while you remove the top nut so that it doesn't bounce off your head.
Old Feb 24, 2012 | 06:45 PM
Bigblue11's Avatar
Another person helping along with that spring compressor. The use of loc-tite is a must!
Old Feb 24, 2012 | 06:59 PM
if your have a autozone near by, they have a free loaner spring compressor. You actually pay for it but they return all your cash when you return the tool. Its a one man job in about 4 hours the first time. Get some camber bolts and have a front end alignment done after the install is complete.
Old Feb 25, 2012 | 02:05 PM
CaptDistraction's Avatar
I did it without a spring compressor (I know, bad bad), but to release the stock springs, I placed a jack under the Arm assembly, removed the top plate 4 nuts, and then removed the nut securing the strut to the top plate/mount. Then slowly lowered the jack, which allowed the spring to relax and be removed.
For both the Roush and Eibach Springs I've used, the springs were short enough that I could get the top plates back on the assembled strut by hand.
Do at your own risk, make sure you're aware of where the forces are and how the parts move in the suspension system. I like to avoid using spring compressors whenever possible, as they're the work of the evil-knuckle-busting-tool-devil. So far on the mustang I've been able to avoid it.
Old Feb 25, 2012 | 03:46 PM
Bigblue11's Avatar
^ Not to sound like a retarded echo but really be careful like he said using this method! ^
Old Feb 25, 2012 | 05:00 PM
That's all great info. Thanks guys. And if I get the springs is the only other stuff I need camber bolts and an alignment? Maybe panhard bar too I've heard.
Old Feb 26, 2012 | 03:04 AM
Bigblue11's Avatar
Adjustable panhard. Is your GT a non-brembo? If so i had to upgrade to the GT500 mounts (w/ Steeda HD's) because of premature wear of the mount on the passenger side.
Old Feb 26, 2012 | 06:08 AM
go with the gt mounts over the gt500 mounts I was told by Sam Strano they are not worth the extra cash.
Old Feb 26, 2012 | 01:05 PM
Mines an 06. Haha I with I had that option
Old Feb 26, 2012 | 05:42 PM
LEwis26's Avatar
So why are you posting in the 2010-2013 section if you have an 06?
Old Feb 26, 2012 | 07:47 PM
Because there's no suspension section in the 05-09 and no one really answered my questions in those sections.
Old Feb 27, 2012 | 03:39 PM
I just realized captdistraction posted on my thread. Haha I'm honored. I've been looking at your car for days now and the stance you have with the wheels is perfect IMO. Great looking car man
