bad Koni struts?
Old Sep 20, 2015 | 09:31 AM
dohc97's Avatar
bad Koni struts?
I am in the process of putting in new koni orange struts in my 14 Gt. When we took off the band in one of the struts, the strut stayed in the compressed state. Isn't it supposed to extend when the band is taken off? Do I have a bad strut in here?
Old Sep 20, 2015 | 10:17 AM
houtex's Avatar
You need to turn the shaft 1/4 counter clockwise looking 'down' on the strut. Or clockwise. Whichever it will move. This ensures it's not locked up in that direction.
Then you need to cycle the strut a few times, pulling the shaft out, then pushing it back in, until it is resistive in both directions.
Then it should be fine. If it doesn't do this, then yes, the strut is bad.
Reason: Shipping it in the compressed state loads the strut up on one side, so there's nothing on the other one. Slamming in the car and then going off and bouncing around will kill it in a hurry. So you have to equalize the gas/fluid in a shock/strut before installation. About 5-10 cycles should do it.
Old Sep 21, 2015 | 07:25 AM
dohc97's Avatar
We did what you suggested and it worked just fine. thanks..
Old Sep 21, 2015 | 08:04 PM
houtex's Avatar
Excellent! Enjoy dem Konis!
Old Sep 24, 2015 | 01:52 AM
2012White5.0's Avatar
bad Koni struts?
I wouldn't bother trying to make them work. I had the same issue with mine. Once I had them on the car for a few days they started to squeak. Had to wait for replacements and redo the job.
Rando
Aug 25, 2021 11:12 AM
RoushRS3
Sep 29, 2015 08:03 PM
GLOCKer
Sep 28, 2015 05:20 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
