bad Koni struts?
bad Koni struts?
I am in the process of putting in new koni orange struts in my 14 Gt. When we took off the band in one of the struts, the strut stayed in the compressed state. Isn't it supposed to extend when the band is taken off? Do I have a bad strut in here?
You need to turn the shaft 1/4 counter clockwise looking 'down' on the strut. Or clockwise. Whichever it will move. This ensures it's not locked up in that direction.
Then you need to cycle the strut a few times, pulling the shaft out, then pushing it back in, until it is resistive in both directions.
Then it should be fine. If it doesn't do this, then yes, the strut is bad.
Reason: Shipping it in the compressed state loads the strut up on one side, so there's nothing on the other one. Slamming in the car and then going off and bouncing around will kill it in a hurry. So you have to equalize the gas/fluid in a shock/strut before installation. About 5-10 cycles should do it.
bad Koni struts?
Originally Posted by dohc97
We did what you suggested and it worked just fine. thanks..
Rando
Aug 25, 2021 11:12 AM
