More pics tomorrow probably. I will be getting the adjustable PHB soon. I will need it anyway eventually. As for the speedo, I am just watching my speed and going a hair under the limit because I'm actually going faster since the tire is a larger radius. Eventually when I have a tuner I will do it that way but until then I don't mind. So far in the 35degree weather and rain these things stick amazingly well.
I think I would be less worried about the speed. You can adjust for that. But not having an accurate odo might bother me a bit. Especially if the new tire size was putting on additional miles.
The 275/40's are only about a 1/2" taller then the std 255/40 Pirellis on a Brembo car.
But their the same height as the 245/45's that are std on other 19" wheels so I do not believe a speedo recalibration is needed. |
Originally Posted by Black Fire
(Post 6740212)
Here you go Mike
275/40/19 Cooper RS3 A's Stock ride height. http://i257.photobucket.com/albums/h...ps00b29018.jpg Looks good! No extra 4x4 looks. Thats a kid who is being brought up right. :) So... will the Boss sized tires fit on the stock Brembo wheels and still perfom ok? IIRC, the Boss wheels are a bit wider... |
The rears on the BOSS are 10" wide and a 285. That's pushing it on the 9" wheel. There will be a lot of bulge and a lot of "squish" side to side.
Originally Posted by MRGTX
(Post 6750116)
:nice:
Looks good! No extra 4x4 looks. Thats a kid who is being brought up right. :) So... will the Boss sized tires fit on the stock Brembo wheels and still perfom ok? IIRC, the Boss wheels are a bit wider... Thanks, the pic is on the famous Woodward Ave. Taken at our weekly hangout spot. My Daughter has been coming out with us since she was 2 months old she is 8 now.
(Post 6750274)
Boss rear wheels are 9.5's and they run a 285/35. There are several people running 285/35's on stock 9" Brembo's. I personally would stay away from anything bigger then the 275's. I am planning on getting some 19x10's on all four corners down the road and will be going 285/35's. |
(Post 6750718)
Thanks, the pic is on the famous Woodward Ave. Taken at our weekly hangout spot. My Daughter has been coming out with us since she was 2 months old she is 8 now. Boss rear wheels are 9.5's and they run a 285/35. There are several people running 285/35's on stock 9" Brembo's. I personally would stay away from anything bigger then the 275's. I am planning on getting some 19x10's on all four corners down the road and will be going 285/35's. |
Originally Posted by wheelman
(Post 6750724)
So 285/35s on 19x10s wont rub up front? Planning 9.5s with 275s but 10s are easier to find if they'll work up front.
There are several people running 10"+ wide wheels on the front the key is nailing the wheel offsets. http://www.s197forum.com/forum/showthread.php?t=88803 |
(Post 6750733)
Maybe it was just the BOSS LS rears. That were 10. The 302S wheels are 18x10 Squared I think.
(Post 6748354)
Even stock ride height cars are biased towards the left and would need an Adj. Panhard Bar.
