Gotta Have It Green
dropped my GHIG
Old Jan 12, 2013 | 01:40 PM
Bushguts's Avatar
dropped my GHIG
before drop
new parts (LCA and relocation brackets and adjustable panhard bar)
shifter bracket (stock vs aftermarket)
in this pic you see a box that is where the shifter bracket connects to. what causes the 3rd gear mis shift is the stock bracket is rubber and the box moves inside that rubber and the factory shift linkage line goes inside that bracket and by that box moving it mis aligns the shift causing you to miss the gear
after drop
the car now has no more wheel hop and now it hooks better. no body roll and it handles like an import, lol. the relocation brackets changed the pinion angle downward resulting in making the tires dig in the ground and gain traction. i also no longer miss 3rd gear. all in all it was well worth it. the car feels more planted and is actually faster because it no longer hops. i will also be making a minor adjustment to the LCA. i put it on the top notch and i later found out that was for stock ride height. i will be moving the LCA to the middle hole.
Old Jan 12, 2013 | 01:52 PM
#13's Avatar
Something doesn't look right...either the wheels are too small or its dropped too low, maybe both
Old Jan 12, 2013 | 02:08 PM
Bushguts's Avatar
i say the lighting is off. too much shadow. its def not dropped too low. i adjusted the brightness so it can be better seen
Old Jan 12, 2013 | 03:04 PM
Looking Gooooooood
Old Jan 12, 2013 | 03:27 PM
Mikey's Avatar
I like the stance, which lowering springs did you go with?
Old Jan 12, 2013 | 04:23 PM
Tron's Avatar
Looks great, well done.
Old Jan 12, 2013 | 04:28 PM
SilverSkoundrel's Avatar
i love it
Old Jan 12, 2013 | 05:16 PM
Bushguts's Avatar
Thanks, its eibach pro kit
Old Jan 12, 2013 | 05:24 PM
Getportfolio's Avatar
I think it turned out tastefully done and looks **** good.
Old Jan 12, 2013 | 08:59 PM
Pilks's Avatar
Nicely detailed, thanks for the posts
Old Jan 12, 2013 | 10:23 PM
That's the kit I'm looking at got my sixxer. Their pro kit for mine
Old Jan 12, 2013 | 10:32 PM
Fenderaddict2's Avatar
Like the drop, but think I'd love it if there was a bit of take with the rear just less than .5" higher.
Old Jan 15, 2013 | 10:37 AM
GreenCars's Avatar
Looks good but I like a bit more rake to the looks like was said just a tad higher in the rear.
Old Jan 15, 2013 | 08:00 PM
Bushguts's Avatar
The point of lowering it was to level out the rear with the front. The jacked up rear just looks bad imo.
Old Jan 15, 2013 | 08:10 PM
#13's Avatar
The nose up look is worse. IMO the rear needs to be a little higher than the front
Old Jan 15, 2013 | 08:14 PM
looks good!
Old Jan 16, 2013 | 10:46 AM
Bushguts's Avatar
the nose isnt higher than the rear. its almost level with the rear. i dont see how the rear being jacked up looks good.
today
Old Jan 16, 2013 | 10:56 AM
Shhhh's Avatar
Well this is why people can modify their Mustang to their liking. As with artwork you're lucky if half the people like it. It looks like you plasti-dipped your rims? As for the drop I personally think it looks like you have a fat person hiding in the trunk, but then again I prefer the back to be a little higher. Love the detailed post though.
Old Jan 16, 2013 | 11:18 AM
Bushguts's Avatar
i just cant understand why people like the rear jacked waay high on a stang. if you can see the tire thru the fenderwell from standing 10ft away that is unacceptable to me. not only does it look dumb, it hinders handling.
Old Jan 16, 2013 | 11:28 AM
Shhhh's Avatar
Ok maybe the picture you posted above on the hill with the angled lines was messing with me. The picture you JUST posted above my post looks really nice.
