2012-2013 BOSS 302
Will 18" wheels fit the boss?
Old Sep 27, 2013 | 08:01 PM
Hillbillyred's Avatar
Title says it all, gettin ready to pull the trigger on new wheels and tires. What 18's will fit? I want to square them out go maybe 18x9's 18x10's? Doing this for more tire sizes and options. Having a hell of a hard time finding the tires i want in the sizes i want in the 19". Got em all day long in 18's. So i just need to know what width and offset will fit and work to be able to run a 295 ish width in the rear and in front.
Thanks for any input.
Old Sep 27, 2013 | 09:40 PM
DGRacing's Avatar
Any of the 302s, 302r BBS 18x9.5,18x10,18x10.5 will work great. strong, lightweight
http://www.shopcapaldiracing.com/col...2r-wheel-18x10
Old Sep 28, 2013 | 06:20 AM
So with a wheel like that i should be able to run say an 18x10 wheel with a 285 or 295 width tire on all 4 corners?
Old Sep 28, 2013 | 07:09 AM
DGRacing's Avatar
Yep. Thats what I do. However depending on the tire section width you may have to cut/grind the endlink strut bolt. No biggy.
This pic is the 18x10 wheel. Clears the strut but the rubber doesn't clear the stud well.
Old Sep 28, 2013 | 11:12 AM
Sweet any clue what backspacing and offset you are runnin? I have looked at the link you provided and checked the specs on those wheels. I am lookin at some on american muscle and wanna check those specs in comparison i am hoping to find an 18x10 wheel and run 285's all round.
Old Sep 28, 2013 | 01:47 PM
JScheier's Avatar
For an 18x10 wheel, you want around a +43 offset. That will allow you to rotate front / rear.
I run the D-Force wheels on the track with a 305/650/18 at all four corners. I do not have OEM front struts, so no clearance issues. 285x35x18 should clear the front with OEM struts no problem with this size / offset.
Old Sep 28, 2013 | 06:15 PM
Sweet thanks guys. I knew id get the right answers here!
Old Sep 29, 2013 | 10:04 AM
DGRacing's Avatar
The BBS Boss wheels I think have 7.5" backspacing and 45+mm offset.
Old Sep 29, 2013 | 07:21 PM
Thanks again guys just the info i needed. Wont be for a cple months but im gonna order them soon. Ill drop back in with some pics once i get them on.
Old Sep 29, 2013 | 11:58 PM
JPC's Avatar
JPC
my D-force rims are 18x10 fits fine from Vorshlag:
http://www.vorshlag.com/index.php?cPath=141_142_268
Old Oct 2, 2013 | 08:40 AM
cloud9's Avatar
Yes. 18 x 10.5 and 18 x 9.5 Enkei PF01s work well for stuffing a lot of rubber under the car. 315/30/18 and 295/30/18 R6s
Ecostang
Nov 3, 2022 08:50 PM
tdf017
Aug 5, 2015 10:13 AM
Jul 17, 2015 05:40 PM
