We don't need track key for launch control
i was having some stuff done on my car at Dallas Mustang today and was complaining that I would miss launch control at the strip. that was really the only thing i miss since the cammed tune can be done already on aftermarket tunes. Archie over at Dallas Mustang said he knew a way to do it and went about programming a tune only launch control in my strip tune for the Boss. Granted, it's not as easy to set as the TracKey tune, but once you get it right you shouldn't have to fiddle much. You set the hold RPM using the SCT. the video below is the launch control working. It;s set at 2500 rpm hold and then when the clutch comes up it automatically goes to WOT. Archie thinks this will work on normal GTs too. You can see it in the vid below:
Pretty cool they're able to program that in!
Thinking of "launch control", though, I can't help but think of the Top Gear episode with the GTR... "Launch Control" is described in-depth at about 5:50...
http://www.youtube.com/watch?v=CNAI0...eature=related
MSD makes a controller to do this also. You set the launch RPM in 100 rpm increments by adjusting a couple of adjusters with a small screw driver. You hold the clutch pedal to the floor, activate the MSD unit and hold the gas pedal to the floor and the MSD box stutters the ignition at the selected RPM until you release the clutch pedal, which then you go to WOT.
In other words... some warranty is better than NO warranty
Ah yes, Ive good times with the msd 'stutter box' in my friends cobra
anyways i have an aftermarket tune also..... CAI.... mufflers.... the CAI required it made the motor run lean, if something breaks its simple you put your stock stuff back on and put the stock programing back in, if you can do this as a mustang owner that wants to play alittle...... maybe you should buy a vette or BMW
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by Resolution78
as im buying the track key programing this is a mute point to me, i have a friend with a 2003 cobra, every time he took it in they would check it for uneven tire wear to sea if he was doing burnout......
What a Maroon.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by boss man
What a Marron
Also regarding the detection of aftermarket tunes, is their some sort of hidden black box that keeps a nicely hidden record of the vehicles usage? This is a very 'big brother' slippery slope as relating to the owners privacy rights. Bringing my car in for warranty service shouldn't allow a dealer to go digging into a little black box on a fishing expedition for warranty nullifying mods. Oh I am sure stuff like this can be rationalized all in the name of SAFETY...
This might make an interesting thread on its own regarding what, if any, 'black box/event recorder' exists on new Mustangs and what legal right a dealer has or hasn't to do this.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by ace72ace
This "measuring tread depth" thing is bogus. If you know you have a dealer that pulls crap, get yourself a set of steel junkyard rims and put on the absolute cheapest tires you can find for each trip you go in for service. Let them measure the depth all they want. What are they going to do next, start some tv show CSI type of automotive forensic analysis of your rear wheel wells looking for "excessive tire compound particulates" ? Or perhaps 'demand' to see 'your real tires' ?
they can't tell the ecm was flashed, just that it was reset. that comes from the tuner ive been using, who work at a dealership until a year or so ago.
i have been going to other shops not ford related with secondary warrenties ....ohh go figure those are third parties who have nothing to due with ford
plus i may have a few friends at some dealers
I have it all answered on one thread and ill link it here. Gotta wait till I get on a pc to do it though. But it is simply a pcm reflash counter that counts the number of flashes you do to a pcm. They can match the flash amount with fords record to see if someone has been into the pcm tuning other than themselfs.
so what your saying is buy another PCM before i take it in lol
seroiusly i like things to run good and last a long time, so my tuner doesnt push the limits....... but with a CAI it threw the air fuel mixture off, required to be corrected.... i didnt want it to run lean and ruin my engine anyways i drive the hell outa my car, had it since september 10 and it has 5k miles on it already. my goal is to have the 2012 boss with the MOST milage i would like to see it go over the 1,000,000 mile mark one day... the way i drive its possible..... a few motors and transmissions later but it wil always stay N/A and in the idea of how ford designed it
That's great news!! that was the only I was lacking as well. Shane, do you control it off of the cruise control switches as well? Or controlled by the SCT? Is it something the end user can program through the SCT or does it have to be added by a tuner? Thanks for the pioneering Shane!!
launch hold rpm is controlled using the adj options menu in the SCT tuner, iirc the parameter is neutral idle for adjusting launch rpm. as for the other part, i have no idea what has to be done in the tune to tell the car to go WOT once it sense the clutch is fully released.
