Turn downs
Turn downs
I know the side exhausts supposedly don't increase the flow. So. Has anyone or does someone make a kit to make the boss side exit only with no rear tails? Seems like it would be nice to have some tire warmers on it.
I can't tell you for sure where I read it. I was researching if the exhaust flows with and without the plates. I read that the side exits are more like resonators and don't bring exaust pressure down.
After getting a good look, the pipe itself in front of the tires is quite small. It would probably be beastly if those were swapped out for 2 or 3 inch pipes.
It is a bit small, but it does flow. Kooks makes a bigger sidepipe setup, I just wish the tips weren't visible on them. I kinda like the stealthy sidepipe thing.
I don't know if we're still talking about the performance changes with the Boss side pipes, but I have some dyno numbers from my car you may find interesting. It's a 14 GT with the Boss exhaust, GT500 ABs and the GT TracKey. Numbers are max torque/max hp. I used the same dyno like 6 months apart.
1. Stock: 344/364
2. Exhaust with stock calibration: 330/369
3. Exhaust with TracKey calibration: 350/394
On 3, the max number may be a slight overestimate, as the dyno sheet indicates slight wheel spin. So maybe subtract 5 lb-ft?
What I see though is stock for stock, the exhaust made minimal torque loss and minimal HP gain.
The sound, however, while not ear splitting, is extremely satisfying.
1. Stock: 344/364
Detroit Steel
GT350
11/16/16 10:32 AM
MRGTX
6/6/16 04:34 PM
