Track Temps - Cool Tech LLC Update
- What amount of heat are you removing from the water cooling system by removing the water/oil cooler?
- What amount of restriction are you removing from the water cooling system by removing the restrictive lower radiator hose (bypass for cooler)?
- What amount of heat is the oil cooler dissipating which will flow to the radiator in the air stream?
All of these would be trial and error... but in my experience on other race cars, it should result in reduced oil and water temps given that the oil cooler is appropriately sized and the air flow path is not overly reduced.
Will the oil cooler placement adversely affect the cooling ability of the radiator?
First off, you can't see the radiator in any of the pics as the AC Condensor covers the ENTIRE radiator. In the area behind our oil cooler instead of having, let's say 90 degree ambient air, you are going to have maybe 130-150? degree ambient air "cooling" that section of the radiator. (The 130-150F is a guess as the cooler itself will probably be 220-240F but it won't shed that kind of heat depending on air flow, etc.) Anyway - it's complicated... and that's why we are testing!! We now have two key gauges - both detailed water temp and detailed oil temp. We will be able to compare OEM to our modified LS. Looks like track temps are going to "cooperate" for our high-heat testing sessions where 90-95F daytime temps are anticipated.... on a course with a straightway where we will see speeds of 130-140MPH?
Rocketman... I really appreciate your help driving the LS. If you are OK, I'd like you to make a few hot laps in this one and then in Apollo's. We're installing an oil temp gauge in Terry's too so we'll be able to get some good data points about the effectivity of the cooler.
What is the likelihood that installing a larger rad would be sufficient? There are a lot of parts involved in the external oil cooler kit. That's more weight, more cost, more to go wrong, etc. etc. I am sure that you've considered this already, I just want to get your thoughts on the subject.
Well Thursday's a big day then I'll be testing the rad Thursday as well. Unfortunately doesn't look like the weather's cooperating. Sunny and 81. Oh well, I'll be pushing it hard so will still have a good idea of temp differences from previous days with this ambient.
What is interesting, however, and a data point I'm looking forward to is oil temperatures. As OEM, owners have only the ability to see coolant temps - and this only really in the LS models with the dash gauge. We have already established that the coolant temps are outside many people's comfort zone for engine longevity/sustainability at 240F +. I too have strong expectations as to what the larger radiator will do to address this. But, oil temperatures - somewhat independent of water temps are also critical. It is conceivable that you can solve one without "solving" the other. We have equipped our oil-cooler equipped car with a oil temp gauge and today we are putting the same gauge in an OEM LS. Both cars will be on the same track, the same day, with hopefully the same expert driver (Rocketman), so we will have the opportunity to see OEM oil tmps for the first time - and also how those temps are effected with the inclusion of the air to oil cooler. Track temps are predicted to be 90F+ next week.... not ideal for the best time at a track day but more or less ideal for the testing that we want to do. Now, we just have to get that gauge installed and get all the cars loaded into the carrier for their trek up to Utah!
Kendall - How easy/difficult is it going to be to access the oil filter after relocation for doing oil changes? Would it require removal of the Laguna Seca splitter for cars equipped with it?
Exactly. Wish we had oil temp. I need to figure out where to install a sender to connect to my Aeroforce gauge. This is why even if I solve the ECT issue, I may still do an oil cooler.
I will most likely do the same. Oil temps are something to be concerned about if you are going to track this car. A gauge and cooler are high on my Santa list for the winter
I think after September's track events, I'll be able to track it until about April of next year until it starts really getting hot again here in AZ.
So by then this should all be settled due to everyone's pioneering w/ additional cooling measures
I'll have my non-LS Boss in Utah for some temp comparisons. Hopefully the work I've done to the car will povide some benefit.
FYI: My superstar son (Ryan) finished the oil temp gauge install in Terry's car - a proof point that you can install oil temp in any of the OEM bosses.
#40
