2012-2013 BOSS 302
Taking weight off the front end
Old Jul 19, 2011 | 08:57 AM
Fat Boss's Avatar
Guys-
Taking weight out of the front is one of the best things we can do to improve our cars. Let's list the components or ideas that will help us all accomplish this.
First up: Radiator Support from Steeda: http://www.steeda.com/store/2011-up-...r-support.html
Old Jul 19, 2011 | 09:04 AM
5 DOT 0's Avatar
Move the battery to the trunk.
The cheapest mod is to go on a diet.
Old Jul 19, 2011 | 09:06 AM
cloud9's Avatar
I know this isn't all off the front, but here's what I've got:
Enkei PF01 wheels/Nitto Tires:
Front 59 stock vs 42 - 17 lbs each x 2 = 34 lbs
Rear 60.5 stock vs 47.5 - 13 lbs each x 2 = 26 lbs
DBA 5000 front rotors 28 stock vs 20 - 8lbs each x 2 = 16 lbs
Corsa Extreme axle backs (pair) 56 lbs stock vs 24 lbs = 32 lbs.
Total weight savings so far is 108 lbs and 76 of that is rotating mass which gives a bigger benefit.
Old Jul 19, 2011 | 10:42 AM
JScheier's Avatar
Unsprung weight:
Lighter wheels
Coil-over setup (60mm springs)
Old Jul 19, 2011 | 05:10 PM
karman's Avatar
Talking
Drain the Washer Fluid.
Old Jul 19, 2011 | 05:29 PM
MyStang2010GB's Avatar
No FAT CHICKS!!
Old Jul 19, 2011 | 06:02 PM
2010MustangGT's Avatar
Go on a diet... Lose 20lbs...
Old Jul 19, 2011 | 07:01 PM
rmaginnis's Avatar
I suspect that the suspension is designed & optimized with the factory F-R weight ratio. Lightening the front may affect the overall handling?
Old Jul 19, 2011 | 08:40 PM
Bueller's Avatar
Carbon fiber hood, lighter bumper supports, brake rotors with aluminum hats. If you pull enough weight off, you may need adjustable coil-overs to adjust the cross-weights (does not help with F-R or L-R though).
While on this subject, did anyone put their Boss on scales to get the corner and cross-weights? Just curious to know what the factory cross-weights are.
Old Jul 19, 2011 | 09:19 PM
adam81's Avatar
I think cloud9 has the best idea here. He kills two birds with his brake and tire setup. Better stopping and grip as well as a weight lose. A large percentage of which is unsprung which makes a HUGE difference. Lightning up the exhaust and front seats is the next "value" step. From then on it gets a lot more expensive to remove weight.......
Old Jul 20, 2011 | 05:23 AM
LQQK's Avatar
Originally Posted by Bueller
Carbon fiber hood
Old Jul 20, 2011 | 07:30 AM
Fat Boss's Avatar
Some good ideas here guys! If possible we should try and put $'s/lb savings. For example the radiator support in my first post would work out to about $20/lb saved. And yes, I guess I could reduce the size of my fuel tank for the s@x machine for free...
Old Jul 20, 2011 | 09:38 AM
PITT BOSS's Avatar
Drill holes in "fake mesh" area in grill and remove hood decal.
Old Jul 20, 2011 | 09:49 AM
Barricade's Avatar
Im just plain screwed....
Old Jul 20, 2011 | 10:55 AM
iDrive's Avatar
You are correct, it will affect handling, braking and acceleration. All improve!
Dave
Old Jul 20, 2011 | 10:59 AM
iDrive's Avatar
My racing buddy and I did on his scales. I'll have to post the data later from home. I recall they were pretty good to start off with.
Dave
Old Jul 20, 2011 | 07:37 PM
Ministang's Avatar
I saved 17.5 lbs off my front end by replacing the stock battery with an Odyssey PC680 battery. The Odyssey PC545 I had in my Bullitt was another 3 lbs lighter.
Old Jul 20, 2011 | 08:12 PM
Bueller's Avatar
Dave
Very cool, please post if you can.
Old Jul 20, 2011 | 10:45 PM
rmaginnis's Avatar
Dave
Braking and acceleration yes. Handling no if you only remove weight from the front - it may be no worse, but it won't be any better.
Old Jul 21, 2011 | 06:01 AM
Dean#4AI's Avatar
I would love to hear your reasoning on the handling piece because I'm not buying it.
