2012-2013 BOSS 302
Strange sound at 3K + rpms
Old Oct 8, 2012 | 04:24 PM
CrazyBrain's Avatar
I just went riding around some back roads, nothing crazy and I starting getting a weird sound. its hard to describe, but I'll try my best. this all happened after the engine/ trans was good and warmed up.
Its definitely mechanical in nature. its starts at around 3K in all gears (except 6th- didn't go that fast.) it has an almost rotational sound, it gets louder with the rpm. If I let off the gas, still in gear, it stops. It does not happen in neutral and just rev'ing the engine. it sounds like its coming from under the shifter area. its like a roaring/ whurring (sp) sound. its not a grinding sound.
My immediate thoughts are :
A) clutch assembly related
B) internal trans related
Thoughts?
Old Oct 10, 2012 | 05:14 AM
CrazyBrain's Avatar
Update-
went out for a drive last night to see what factors cause the noise. I now believe its actually the ring and pinion. the sound is more of whine and its always there, just very quiet at low RPM. at 3200-3500 its the most pronounced. above 4200 its starts to go away.
This is very similar to when I had my motive 4.10's installed on my 03 GT.
Old Oct 17, 2012 | 07:35 AM
Boss2511's Avatar
I have noticed that my gears have started to whine here as of late. I am so used to the noise in previous mustangs that I hardly notice it most of the time lol
Old Oct 17, 2012 | 10:07 PM
Brandon302's Avatar
From what I have read the whine could also be from the trans, apparently the fluid allows sound to come through.
Old Nov 12, 2014 | 11:45 AM
CrazyBrain's Avatar
Update- The issue has been resolved to my satisfaction. The culprit was the throwout bearing assembly. The second dealer I went too, Pat Millikan Ford, has a great trans tech. I took the guy for a hard/ fast ride and he had me press on the clutch slightly while it would whine. The tone of the sound would change immediately. 4 days later....no more whining!
Old Nov 12, 2014 | 12:31 PM
Brandon302's Avatar
Glad to see it got resolved, where could you hear the sound coming from?
Old Nov 13, 2014 | 01:25 PM
CrazyBrain's Avatar
to me it sounded like it came from rear of the vehicle, that proved to be incorrect. the only good thing about it was that I could make it happen when ever I drove it hard. it was easy to show the two ford techs I took for rides. #1 got it wrong, #2 nailed it in 5 minutes.
Old Nov 13, 2014 | 01:42 PM
Brandon302's Avatar
That is really interesting, I have had a whine since about 5k miles maybe less and always thought it was the 3.73, mine sounds like it is coming from the back also and got worst after a UCA install. I may have to see if Ford can check the trans.
Old Nov 13, 2014 | 02:28 PM
CrazyBrain's Avatar
If you hear the whine, press on the clutch pedal a slight bit and see if the tone of the whine changes. thats how the trans tech determined it was the throwout bearing. the 1st dealer only replaced the trans fluid. this didnt do anything at all.
Old Nov 13, 2014 | 02:35 PM
Brandon302's Avatar
Would it also lessen if you weren't on the gas?
Old Nov 14, 2014 | 07:42 AM
CrazyBrain's Avatar
yes, it was dependent on power from the engine. it would stop if i let off the gas, regardless of gear and RPM.
Rando
Aug 25, 2021 11:12 AM
Glenn
73
Apr 26, 2016 12:22 PM
ricky1728
Feb 11, 2016 07:25 PM
