2012-2013 BOSS 302
To Stagger or Not Stagger
Old Jul 26, 2021 | 10:41 AM
Glockem45's Avatar
Question To Stagger or Not Stagger
So, I am looking at ordering a new set of wheels and tires for my Boss 302. Should i get the same stagger set up that the Boss came with, or should i get the same size on all four corners?
Benefits of the staggered?
Benefits of the same size?
Old Jul 26, 2021 | 11:23 AM
Bert's Avatar
did the Boss really come with a staggered setup? I thought it was set up as a road track car, meaning same wheels and tires on all 4 corners. Or did they use the same wheels, with wider tires on back?
benefits of staggered: increases traction on back; and some people like the look, with fatter tires on back
benefits of same size, aka "squared" -- more balanced handling on track (less understeerish) ; can rotate tires
will you be using the car on a road track? if yes -- you want the widest tires you can get on the front, which is about 305 on 11" wheel with perfect offset; or you could go a bit narrower for less critical fitment; and the same wheels/tires on the back
Old Jul 26, 2021 | 11:57 AM
Glockem45's Avatar
Question
I believe the stock Boss 302 front wheels are 19x9" and the rears are 19x9.5"
The stock front tire is the 255/40/19
The stock rear tire is a 285/35/19
This would primarily be for street duty, until i can get into track days, racing, etc.
Old Jul 27, 2021 | 08:24 AM
cholmes1's Avatar
I would recommend going square. I have 19x11 w 305s on all corners and it has worked great. With a spacer up front you can achieve a true rotation option that is not possible with staggers or playing with offsets.
Old Jul 27, 2021 | 08:26 AM
Bert's Avatar
Originally Posted by cholmes1
. . . . I have 19x11 w 305s on all corners and it has worked great. . . . .
that is a track oriented set-up, correct?
how is it on the street -- lots of tramlining, hydroplaning, generally heavy steering?
Old Jul 27, 2021 | 09:38 AM
cholmes1's Avatar
Yes, the true square is a track setup. That said, mine is 99% street/show and the occasional 0-60 sprint event at Pikes Peak.
The car is certainly more connected and no noticeable issues with tramlining. Steering weight is the same at speed but in parking lots you notice a slight change. I can’t speak to hydroplane as the car has never been in the rain since purchase.
The biggest key for me was having the correct camber (-2.5 up front) paired with a revised spring and altered strut settings. I also had to trim the rear wheel well brackets.
For reference, I have ‘13 302 LS with OEM struts at setting 2, Steeda Boss springs, and 302S end-links, 302S adjustable panhards, and the 302S/R LCAs and brackets. The wheels are Apex and the tires are PS4s
MRGTX
May 1, 2021 05:29 AM
Driver72
2012-2013 BOSS 302
Mar 7, 2012 02:05 AM
UnrealFord
2012-2013 BOSS 302
72
Feb 27, 2012 12:11 PM
Evil_Capri
Sep 24, 2005 02:39 PM
