2012-2013 BOSS 302
Removing Stock shifter ball....
Old May 26, 2014 | 06:14 PM
ulev1st's Avatar
Is there a good way to remove this? I want to reuse it but it is being a real pain!! Suggestions please....
Old May 26, 2014 | 06:29 PM
aircare84's Avatar
Heat up with a hair dryer on the hottest setting & use a strap wrench.
Not gonna get off with your bare hands.
Old May 26, 2014 | 08:11 PM
ulev1st's Avatar
thanks..
Old May 26, 2014 | 09:41 PM
maddog2's Avatar
I used a strap wrench and my hand.
Old May 27, 2014 | 04:13 AM
boss man's Avatar
Same hear... strap wrench and hand. Ford really did not want that to come off I guess. I thought I was going to break the shifter but at the last moment it broke free.
Old May 27, 2014 | 11:00 AM
93 LX 5.0's Avatar
Strap wrench w/o heat here. Requires some force.
Old May 27, 2014 | 11:04 AM
DarrenGT's Avatar
woossies!
Old May 27, 2014 | 01:19 PM
Senderofan's Avatar
Originally Posted by DarrenGT
woossies!
So are you saying you used the hair drier to heat up your hand...and then removed the shifter **** with said hand? Now that's Bada$$ Just Joking.
I used a strap wrench.....took a pretty fair amount of torque....more than I had envisioned.
Wayne
Old May 27, 2014 | 03:20 PM
DarrenGT's Avatar
Old May 28, 2014 | 01:33 PM
Krohn's Avatar
Sort of on the same topic...
How about putting it back on? When I bought mine used, it already had the MGW shifter in it but with the Boss shift **** mounted. The shift **** snugs up facing roughly 10-deg from dead ahead. It'll remain at 0-deg unless I apply any to a little clockwise rotation... any idea how to make it sit perfectly straight while torqued down? OR! is that normal and I need to grab a strap wrench and really wrench down the other 350-deg?
Old May 28, 2014 | 04:57 PM
TripleBlack14's Avatar
It took a couple of trys, but I got mine off by hand. I don't need no stinkin' strap wrench.
Still can't open a jar of pickles though.
Tom
Old May 28, 2014 | 07:42 PM
TMSBOSS's Avatar
The MGW shift **** shaft is threaded into the upper shifter body. Loosen the jamb nut holding the shaft and adjust as needed.
Remove the console, simply pulls up, disconnect the wire connector and set aside. Loosen nut and adjust. Reassemble in opposite order.
Takes about 5 minutes once you get used to the process.
Old May 28, 2014 | 08:13 PM
ulev1st's Avatar
Got it off...what a pain!
New Barton shifter will be here tomorrow!
Old May 29, 2014 | 07:25 AM
Krohn's Avatar
Takes about 5 minutes once you get seed to the process.
Perfect! This will be easy. Thanks for the quick response!
Congratulations! Pics after install.
Old Jun 4, 2014 | 02:27 PM
ace72ace's Avatar
You won't want to try over tightening another 350 degrees, you will end up stripping threads or maybe crack the ball. I have to do this also, adjust the jam nut on the MGW after taking my console off a few times for the stereo install.
hpb50
Sep 27, 2023 03:03 PM
2012Kona
Aug 21, 2015 08:36 AM
SilverBullet13
Aug 13, 2015 09:11 AM
