2012-2013 BOSS 302
Rear Wheel and Drag Radial Setup questions
Old Mar 18, 2012 | 02:15 PM
SoFlaBoss's Avatar
Old Mar 18, 2012 | 02:55 PM
SoFlaBoss's Avatar
Old Mar 18, 2012 | 03:30 PM
Mustangfreak's Avatar
OMG PLEASE post pics when you get tires on those weld rims and on the car
Old Mar 18, 2012 | 03:46 PM
SoFlaBoss's Avatar
Old Apr 2, 2012 | 03:14 PM
SoFlaBoss's Avatar
Rear suspension mods, drag wheels & tires
Old Apr 2, 2012 | 04:03 PM
Brawlin' Boss's Avatar
That looks stout!! Looks to be setup very well, now just some valuable seat time and you will definately hit your target.
Old Apr 3, 2012 | 07:32 AM
SoFlaBoss's Avatar
Old Apr 4, 2012 | 06:06 AM
Are you going to get matching 17" fronts, or will thos not clear the brakes? I love the RT-S wheels, was going to put them on my 90 coupe but its gone now.
I might jut get a set for my Boss though now.
Old Apr 4, 2012 | 06:44 AM
SoFlaBoss's Avatar
Old Jun 2, 2012 | 06:42 AM
BracketRacing.com's Avatar
I was about to order the MT ET 275-50/15 but Jegs said they might not fit on a 2013 GT CS without altering the brakes. I think a 15x8 will fit without issues, but I want to make sure and I'm getting different feedback from vendors. Can anyone let me know if this is correct?
Thanks!
Old Jun 2, 2012 | 08:06 AM
SoFlaBoss's Avatar
Old Jun 2, 2012 | 09:26 AM
Originally Posted by SoFlaBoss
I've never heard someone ask if a size of tire will interfere with the brakes. Are you asking if 15"X10" wheels on the back with 275/50-15 tires will clear without modifying anything? If so, the answer is no. You would have to install swaybar relocation brackets. Supposedly, 15"X8" wheels will fit without relocating the rear swaybar.
The Jegs rep said he didn't think a 15"x8" wheel would fit because of an issue with the brake caliper size. I know a 15"x10" needs the sway bar relocation kit, I was wondering if you had any issues with the calipers too.
Thanks!
Old Jun 2, 2012 | 10:52 AM
SoFlaBoss's Avatar
Old Jun 2, 2012 | 11:25 AM
I had no "brake caliper" issues with my Weld RT-S wheels. I just needed the swaybar relocation brackets. However, once the swaybar was relocated, the swaybar was up against both LCA brackets, due to the 25mm thickness and bends of the OE bar on the Boss. I ended up purchasing Steeda's 1-1/4" tubular adjustable bar, which fit perfectly.
I didn't think there was an issue, thank you for the feedback.
I just ordered the MT ET 275/50-15 & 15x8 Race Star Drag Wheels from AmericanMuscle.
Your car looks amazing. Best of luck, I'll follow this thread to see how your 1/4s go.
