Oil Pressure gauge hook up help
I need to hook up my Interceptor gauge and really need to have oil pressure and temp displayed. I ordered the sending units but am wondering where people ar installing the senders?? Cloud9 I saw was talking about it but have not seen a solution as of yet...:dunno: can anyone help me out?
Thanks-Andy |
Bueller??
Mine's not a Boss, but on my 4.6L the easiest way was to get a sandwich oil filter adapter, I plugged in the pressure and temp gauge sending units for one Autometer gauge and the one for the Interceptor (pressure Autometer, temp Interceptor, I believe (not hooked up the gauges yet, though). Ran the car in extremely hot weather over July 4th weekend at PPIR, no problems, no leakage whatsoever. Using the standard Ford Racing filter for my engine, too, just barely fit without touching the front AR bar.
http://www.glowshiftdirect.com/oil-f...-adapters.aspx http://www.glowshiftdirect.com/produ..._large.jpg.jpg |
thanks for the help. My preference would be not to use one of those if possible. I was wondering if the Boss actually has a rear oil pressure sender as the LS gauge apck has the oil pressure gauge?? Also I have seen somewhere that the Boss oil pan has a temp sensor, is this true?
Thanks |
1 Attachment(s)
The sensor on the side of the oil pan is an oil level sensor - not temp or pressure. The pressure sensor is located just under the OEM oil cooler. See the pressure sensor indicated by the (3) in the attached diagram.
Note: We will be testing our new, oil cooler kit at MMP at the end of the Month. Our kit will have provisions for adding a traditional temperature sensor. Attachment 91445 |
Originally Posted by nota4re
(Post 6117827)
BTW your kit would be thermostatic right? |
2 Attachment(s)
Originally Posted by 2006stiguy
(Post 6117836)
Excellent info! So would the factory sensor be readable by the aeroforce interceptor...and if not is there a way to either tap into the wiring for a signal to an aftermarket sensor or install an adaptor for an aftermarket sending unit? I would be VERY interested in your oil cooler setup as I need one ASAP. BTW your kit would be thermostatic right? Thanks
The key here is that the Boss oil pressure gauge mimics the signal sent by the base oil pressure switch. This has to be wired up properly to work, but is an interesting solution. |
Originally Posted by PTRocks
(Post 6117883)
In going through the shop manuals for the Boss, I've determined that if you use the Boss oil pressure sensor, you can replace the original sender with the Boss version and still have the idiot light work.
(Post 6117868)
Of course. We will have a minimum of (4) LS's at MMP at the end of the month for track time, and at least one pro driver. This will be a good shakedown test for the cooler and an ideal way to make comparisons to OEM set-up. Still have some work to do to get the cooler mounted where we want to place it and so there is still risk to the schedule - but we should make it!
1 Attachment(s)
(Post 6117886)
So it sounds like my idea to use an aftermarket sender in the factory location and wire it into the factory sender wiring should work??! It's raining all weekend so i will put the car on jackstands and take a close look at the wiring and if its looks good, install my sender in the factory location and wire it up.
What is not shown in the attached diagram is the circuit that supplies voltage to the oil pressure signal line. It is this circuit which could be damaged if you wire your sensor to that line. Damaging that circuit could cost you your Instrument Cluster, your PCM, or both. |
In going through the shop manuals for the Boss, I've determined that if you use the Boss oil pressure sensor, you can replace the original sender with the Boss version and still have the idiot light work. |
Which days are going to be there? There are several forum members attending Track Attack between August 29-31 including me. |
(Post 6117941)
While true, the OP is looking for a place to get oil temp not oil pressure.
(Post 6117950)
OP is asking for both oil temp and oil pressure.
I really want oil pressure ASAP and i can wait for oil temp when i get a cooler as it should be relatively easy to install a temp sensor at that point PTRocks: So I am confused...Does the LS use a different oil pressure switch than the regular Boss? If so how could i tap the aftermarket gauge into it? Or is this all a waste of time and just figure out some other way to add another sender? And if not how does the LS get pressure, or does the fancy LS gauge pack have the same on/off readings as the low oil pressure dummy light? sorry i am just getting myself confused |
(Post 6117970)
This^
I really want oil pressure ASAP and i can wait for oil temp when i get a cooler as it should be relatively easy to install a temp sensor at that point PTRocks: So I am confused...Does the LS use a different oil pressure switch than the regular Boss? If so how could i tap the aftermarket gauge into it? Or is this all a waste of time and just figure out some other way to add another sender? And if not how does the LS get pressure, or does the fancy LS gauge pack have the same on/off readings as the low oil pressure dummy light? sorry i am just getting myself confused It sounds like trying to go the integrated route is going to create too many headaches for you. I suggest that you look for a tee fitting that will allow you to attach the old and new pressure sensors to the same port on the engine block, and keep all of the wiring separate. |
OP is asking for both oil temp and oil pressure. |
(Post 6117827)
Chris
Are you saying that if I buy the Ford Racing oil pressure gauge used in the LS and the LS oil pressure sender, it will work? If so, do you have the part number? |
Originally Posted by MJockey
(Post 6118307)
Chris
