JLT oil separator
JLT oil separator
Has anyone installed the JLT oil separator? This looks like a necessity considering the high revving engines and the amount of oil I have noticed being burned.
I agree we need them, I am looking at 2 possibilities the JLT and the Steeda oil separators. Advantage to JLT is that it includes the hoses. Steeda requires you to cut the originals. I also think we need to get two...one on each pcv hose pass side and driver side.
I have the JLT for both the passenger and driver side. I have only seen very little oil in the driver side.... However the passenger side sees a lot of oil. I think it is a very good piece and would definitely recommend it to anyone.
1 Post
![Name: p36vF.jpg
Size: 90.4 KB](https://themustangsource.com/forums/attachments/f813/216513d1683056383-jlt-oil-separator-p36vf.jpg)
Here is the new aluminum fitting:
![](http://img69.imageshack.us/img69/7299/jltoilseparator.jpg)
I had one on the pass side since month 2 last year and then when the blower was installed I had Evolution install it again. It still had about the same amount of oil every couple of hundred miles even after the vbower install. I expected the blower to cause MORE blowby and it actually stayed the same
This thread made me curious, so I checked. ~2000 miles since the first oil change and installation of passenger side JLT OS. Looks like 1/4 Oz in the glass. Not worried, as I had some high speed track time.
![Name: ForumRunner_20120415_155507.jpg
Size: 22.2 KB](https://themustangsource.com/forums/attachments/f813/106610d1334523314-jlt-oil-separator-forumrunner_20120415_155507.jpg)
Although this is about the 4.6, thought it might add to your discussion.
https://themustangsource.com/f722/jl...2/#post6315801
