2012-2013 BOSS 302
issues with 4th gear
Old Apr 19, 2015 | 03:00 PM
tek302's Avatar
Here is a vid, you can't really tell but I have 4th problems.
I've learned that I don't feel it go into gear. I almost have to hold it down and let go of clutch and go.
I don't feel the usual click into gear you know?
Think that's a synchro problem? No grinding at all.
Thinking of taking it to ford. I have a blowfish bracket with stock shifter, SS Clutch line. Think they will give me flack when I take it in?
Old Apr 20, 2015 | 08:00 AM
FordService's Avatar
Thinking of taking it to ford. I have a blowfish bracket with stock shifter, SS Clutch line. I have a aed tune. Thunk they will give me flack when I take it in?
Hi tek302,
I agree with your bringing in to your Ford Dealer first and getting it fully diagnosed. Make sure you speak with your service manager if needed. He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
You can schedule an appointment online here.
Deysha
Old Apr 20, 2015 | 08:42 AM
tek302's Avatar
Thank you, I scheduled an appointment at Rockwall ford For the evening.
I'm gonna load my factory tune back onto the vehicle just to get rid of any confusion.
Will get back with more info as they give it to me.
Old Apr 20, 2015 | 09:27 AM
No problem, tek302! Definitely keep me posted.
Deysha
Old Apr 20, 2015 | 11:38 AM
Brandon302's Avatar
Had that happen when I first got the car, usually it was on high rev down shifts. IMO I think the issue is a misaligned shifter and the BF bracket fixed it for me.
Old Apr 20, 2015 | 11:47 AM
tek302's Avatar
I have blowfish bracket. This just started happening
Old Apr 20, 2015 | 12:55 PM
Brandon302's Avatar
Weird, are you shifting at or very close to redline?
Old Apr 20, 2015 | 02:10 PM
tek302's Avatar
It does it under heavy throttle, but fine under normal throttle.
Old Apr 20, 2015 | 06:22 PM
tek302's Avatar
Dropped it off, I'm assuming they won't find anything. Before I let them give it back, I'm gonna ride along with a tech to recreate the issue.
Old Apr 21, 2015 | 10:53 AM
tek302's Avatar
They called me and told me they are replacing 4th gear synchro.
Glad it wasn't my imagination. ..
Old Apr 21, 2015 | 11:33 AM
boss man's Avatar
Nows the time to have the clutch and Install the CJ Pluse Ring. You wont be sorry.
Old Apr 21, 2015 | 11:34 AM
Good news, tek302!
Deysha
Old Apr 21, 2015 | 11:38 AM
tek302's Avatar
CJ pulse ring?
Old Apr 22, 2015 | 02:27 AM
boss man's Avatar
As Per...
http://www.americanmuscle.com/frpp-i...ng-1113gt.html
Pulse Ring was designed to support higher RPM engine builds by extending the RPM range from 7700 to 8100 RPM without signal degradation.
If it's a DD and you have no plans on seeing higher RPM, then it may be not needed. The clutch is a different story. IMO If the trans comes out so dose the stock clutch.
Old Apr 22, 2015 | 06:10 AM
jim woodruff's Avatar
When Ford rebuilt my trans. they also replaced the pluse ring and the up dated crank sensor. Ford has been great to work with.
Old Apr 28, 2015 | 01:22 PM
tek302's Avatar
Seems to be an issue. They say parts are on back order and I won't get my car back until june, maybe.
Very depressing....
Old Apr 28, 2015 | 01:52 PM
Coyote5-0's Avatar
ouch, I dropped mine off yesterday for trans issues and will be riding with the tech tomorrow to duplicate the issue. If mine needs synchros that will suck it have it in the shop that long
Old Apr 28, 2015 | 02:04 PM
Very depressing....
I’m happy to escalate this parts delay for you, tek302. Please PM me with your VIN, dealer, mileage, full name, and best daytime number.
Deysha
Old Apr 28, 2015 | 04:31 PM
tek302's Avatar
Sent you the info, hopefully I can get my car sooner than june. What can be done if the parts are on back order?
Old Apr 29, 2015 | 07:22 AM
Thanks, tek302. The customer service manager will look into (if any) what options are available for you.
Deysha
