First mod of this type...crazy #$@ shift ball
these are about $30 each from EPCO (I also got a blue / black marble swirl one)...
the way it comes from EPCO, it sits a fair amount lower than the stock unit, and it's slightly larger (I believe 2 1/8" vs 2")...and that sure makes more of a difference than I would have thought. Haven't driven with it yet...just mounted / took pictures / posted (as I know we all love pics).
just thought I'd try something a little different / funky.
I'd guess the breakage rate is like 60-70% for stock ***** getting them off the first time. (Thanks Ford!)
Originally Posted by thevidon
Stop fussing around with it - put a wrench on it and crank down. You are probably going to break it getting it off. Just live with it and have your new one ready.
Originally Posted by SINBUSTER007
how did you get the OEM shifter off? ive been trying for days now....
Step 1: Get some aluminum foil and wrap it around the boot for protection. Step 2 apply heat with a HEAT GUN (a hair dryer might work but I don't know if it would get hot enough) to the base of the **** for 5 minutes or so. Step 3: Use a plastic strap wrench if you can't get leverage (if its a pool ball type you'll most likely need a strap wrench) Step 4: bingo!!
thats what im trying NOT to do...break it...if its really that hard then ill just not do it at all...i can live with it stock. i can try the wrenches others are talking about but i dont want to break it.
That does NOT work every time. I had a strap wrench on mine and was cranking on it with a pry bar for extra leverage and it wouldn't come off. I'm glad to hear not all of us got ****ed over though!
I like that ****. I was thinking of ordering exactly that after looking over their site so it's nice to see a real image. What size **** is that?
you were using the same exact wrench? the nylon strap kind or its brother the blue one dont work so well.
Not sure on its size MGW told me it was 2 1/8" but I order a white version of that **** same size and its smaller.
i have the strap wrench but the blue one not the red one. ive cranked on it so much that the rubber strap is about to snap apart from where the "teeth" sink into the rubber part....
i guess i got the shifter k n o b that they added extra loctite too....figures...i was thinking about taking the blue one back and seeing if they would exchange for the red one...
y'all are complaining about it being put together too well...do you realize that??? if it came loose every time you slammed it into second you'd be mad too...just saying...
