2012-2013 BOSS 302
Electric Dump Valves
Old Dec 9, 2010 | 10:49 PM
ApexCars's Avatar
One of the first things I plan to do to my Boss is install electric dump valves. The restrictor plates in the car are going to be installed with 2 bolt flanges but every dump valve system I have found on the net is a 3 bolt system. Can you pick which flanges when you buy the controller or does anyone know where to get a 2 bolt system? Or am I going to have to get new flanges welded on? Seems kind of dumb that Ford would make the system and brag about how easy it is to switch to dump valves and then make a configuration that isn't readily available on the market.
Old Dec 10, 2010 | 07:40 AM
LQQK's Avatar
Someone will make them for the BOSS exhaust, IMO the quad system will also be available for 5.0 mustangs.
LQQK
Old Dec 10, 2010 | 01:46 PM
s197ford's Avatar
Ford Racing will be releasing an electric valve system that is compatible. The system should be available around the time the cars hit the dealerships.
Old Dec 10, 2010 | 01:50 PM
atrain1975's Avatar
... and that would explain why they went with two bolts instead of three.
Old Dec 11, 2010 | 05:10 AM
Dig-It Racing's Avatar
Old Dec 11, 2010 | 09:09 AM
cloud9's Avatar
I'm really hoping I can just pull the plates and be done with it. I wonder if they'll be loud enough to actually get you pulled over???
Old Dec 11, 2010 | 09:42 AM
66sprint200's Avatar
Seriously? Pulled over for sound? ... in South Dakota?
"If a tree falls in.........." oh, you get the picture
I'm running an off-road x-pipe with FR500S mufflers (my neighbors think I'm running open pipes) on my Shelby and nary a nod from the local LEO's. I'll just conveniently "lose" the discs
Old Dec 11, 2010 | 09:43 AM
Bones Applesauce's Avatar
I would think without any kind of baffling there might be a bit of drone going on while on the highway. An electronic system will be ideal.
Old Dec 11, 2010 | 12:05 PM
MustangFanatic's Avatar
I'll definitely do the electric dump valves on my Boss
Old Dec 11, 2010 | 08:11 PM
s197ford's Avatar
Nope, no drone! The sidepipes were developed/tuned for no plates (or open electronic valve...), then tuned down to required sound levels via the orifice plates. There are mini-mufflers engineered into the sidepipes to keep everything in check if the owner chooses to run valves or remove the plates (for off-road use, of course).
Old Dec 11, 2010 | 08:47 PM
LQQK's Avatar
Thanks for the info.
Just guessing, you have good connection's or actually worked on the BOSS development?? Any other tidbits you can divulge/share with us?
LQQK
Old Dec 11, 2010 | 11:24 PM
12C/OBoss's Avatar
LQQK
Same here: BTW if you removed the side pipes and installed turndowns right at the flanged connectors...ie true straight pipe...how would that sound??? I just might experiment with mine like this. We used to run fox body cars with turn dowms right after the mufflers with no tail pipes and they sounded sick as hell with the b303 or other cams in them
BTW This whole idea is offroad only!!
Old Dec 12, 2010 | 12:05 AM
That's great news! I won't be buying any valves then, I'll just keep them open!
Old Dec 12, 2010 | 08:33 AM
cloud9's Avatar
Classic! Yea, they probably won't hear it over the sound of the guns. I just need to find a convenient place to mount the rifle rack. The discs are coming out for the track.
Old Dec 12, 2010 | 06:49 PM
s197ford's Avatar
[quote=2006stiguy;5985169]Same here: BTW if you removed the side pipes and installed turndowns right at the flanged connectors...ie true straight pipe...how would that sound??? I just might experiment with mine like this. We used to run fox body cars with turn dowms right after the mufflers with no tail pipes and they sounded sick as hell with the b303 or other cams in them
It sounds really, really loud. Much louder than a fox w/ dumps after the muffler. It's fun for about 2 minutes... Other than the cats, there is nothing to quiet down the exhaust. Quieter than open headers, but not much. Wouldn't recommend your experiment. Use what comes on the car. You'll like it.
Old Dec 12, 2010 | 06:57 PM
s197ford's Avatar
LQQK
You are a good guesser
Old Dec 12, 2010 | 08:04 PM
LQQK's Avatar
OK, Do you know if the CO BOSS will be displayed in the Midwest at any functions?
LQQK
Old Dec 14, 2010 | 08:47 AM
908ssp's Avatar
LQQK
The International Auto Show in Detroit is just around the corner. I can't imagine it won't be there.
Old Dec 19, 2010 | 07:55 PM
5 DOT 0's Avatar
Any idea what this will cost and how it will function? Where will the switch mount etc. TIA.
Old Dec 19, 2010 | 08:20 PM
PTRocks's Avatar
As long as the button has the word "LOUD" on it, I'll be happy!
