2012-2013 BOSS 302
Damper adjustment
Old Mar 28, 2011 | 05:31 PM
4pipes's Avatar
Damper adjustment
If anyone has tried the 5/5 setting for street use, please post your impression. It kind of difficult for my old eyes to **** with rears too often. I'm tempted to just set them once and forget the.
Old Mar 28, 2011 | 07:56 PM
2012YellowBoss's Avatar
Originally Posted by 4pipes
If anyone has tried the 5/5 setting for street use, please post your impression. It kind of difficult for my 6 old eyes to **** with rears too often. I'm tempted to just set them once and forget the.
I am at 3/3 now. It rained today so no joy riding. I will leave it there then go to 4 then 5. I want to get use to a setting before I change to see the difference.
Old Mar 28, 2011 | 07:57 PM
4pipes's Avatar
Let me know where you end up.
Old Mar 28, 2011 | 07:58 PM
Big Vito's Avatar
Scott is 3 still soft?
Sent from my Droid via iPhone using TMS Forum
Old Mar 28, 2011 | 08:35 PM
Really hard to say because I have not really driven it much. It feels great on 2/2 and 3/3 and did not feel the difference. I need more time to get use the car in general, you know after time you can feel if one tire is a pound low or that tiny little noise. I am not anyway near that point yet.
In any case I would not call it soft, the ride has been very nice so far, I tend to like a very firm ride anyway and on 2/2 I am getting that. I am looking to find changing the setting does to hard cornering. I drove with a 2 rear and 3 front yesterday, should have been 3/3, and in back of an Autozone there is a winding street. I took a right 135 degree turn hard in second, then a 90 turn about 75 feet ahead, again in 2nd. For a second the rear started sliding out but grabbed in a right away. I don't think it was from spinning the tires, it felt more like the whole back end slid out (right) just a bit.
Anyway I am not a race car driver and need a whole lot more time before I can give anyone reliable info on all this.
Old Mar 28, 2011 | 08:38 PM
Big Vito's Avatar
Interesting thank you
Old Mar 28, 2011 | 08:41 PM
1FAFP90's Avatar
It would be interesting to know the real difference between the std and LS settings. Are the rumors true that LS 1 is close to Std 5 ?
Old Mar 28, 2011 | 08:48 PM
4pipes's Avatar
I do recall one of the hot shoe reviews had the fronts at 5 and the rears at 3.
Old Mar 28, 2011 | 08:50 PM
5 DOT 0's Avatar
In for the updates. Have fun testing the settings.
Old Mar 28, 2011 | 08:55 PM
I did not know there was a difference, the difference I know if is things like tires/rims, X-brace, Torsen standard, gauges, and a one mm thicker stabilizer in the rear (I will check mine but not sure the Boss gets the same if you order the torsen).
Boss
SUSPENSION
Front
Independent MacPherson strut with Reverse-L lower control arm, 34.6 mm tubular stabilizer
bar, strut tower brace, adjustable strut damping
Rear
3-link solid axle with limited-slip differential, coil springs,
Panhard bar, 25.0 mm stabilizer bar and adjustable shock damping
LS SUSPENSION
Front
Independent MacPherson strut with Reverse-L lower control arm, 34.6 mm tubular stabilizer bar, strut tower brace, adjustable strut damping
Rear
3-link solid axle with Torsen limited-slip differential, coil springs, Panhard bar, 26.0 mm stabilizer bar, body X-brace and adjustable shock damping
Old Mar 28, 2011 | 08:57 PM
5 DOT 0's Avatar
I don't think it's rumor, it's fact. I believe the Road and Track review makes a comment about that.
Old Mar 28, 2011 | 08:58 PM
1FAFP90's Avatar
iirc, MotorTrend started the rumor of a significant difference between the std and LS settings. Until we can get someone to look up shock part numbers on both cars...
Old Mar 28, 2011 | 09:00 PM
Big Vito's Avatar
But what is the real feel difference?
Old Mar 28, 2011 | 09:01 PM
I could be wrong but what comes out of the motor mags is often not correct, if there was a big difference I would think Ford would have mentioned it. I really would be suprised to see two different adjustable struts and shocks.
Old Mar 28, 2011 | 09:02 PM
5 DOT 0's Avatar
They (again I've read so many reviews but I'm pretty sure it was R&T) stated something like the LS was ok for around town and short trips but would be uncomfortable for long drives. I'll see if I can find the review.
5 DOT 0's Avatar
I'm pretty sure I read a quote from Ford on it as well.
Old Mar 28, 2011 | 09:05 PM
Big Vito's Avatar
I'm sure it will be fine for long trips
Old Mar 28, 2011 | 09:10 PM
5 DOT 0's Avatar
Well it wasn't R&T, MT, or C&D. I'll keep looking.
Old Mar 28, 2011 | 09:21 PM
Well as I said the ride on 2/2 is pretty firm, much more than most anything on the road. I use to drive my 87 Turbo Coupe in "firm ride" all the time, it was nice but this is of course is way better. I was blowing down a country road at over a hundred, came up on some patches in the asphalt and the car really snaps back after going over them. There is no long wave type feeling (sorry I can not find the right words to describe this). Anyway so much to the point it scared me because I was being stupid, this was the first time on this "country" road. So I finished the length of the normally and punched it on the return trip since I knew there was no big potholes in the road.
Old Mar 28, 2011 | 10:08 PM
PTRocks's Avatar
Ford did say that 5 on the Boss was equivalent to 1 on the LS. There are different part numbers for Boss vs LS shocks. Looking for a reference now...
