Clutch on the Floor?
Today I had my first chance to really open the car up. I was at a local airport they let locals race on. I was on my fourth strait pass up 120 and all of the sudden I could not go into 5th gear and the clutch was on the floor. This made me very upset since the car only has 560 miles on it.
Is this normal?
Should I bring it in for inspection by my dealer?
How often does this happen?
Thanks for any help!
Dylan,
Is this normal?
Dylan,
Is this normal?
Dylan,
Is this normal?
Dylan,
Not owning a boss I could not see how that could be "normal" in any sense of the word.. We can assume everything is ok at the moment and the clutch feels normal now? Usually when a clutch ends up on the floor it where it will stay until repairs are made.. at least in my past experience anyway.. Looking forward to other reply's on this. My first thought was the factory shifter because you stated you could not go into 5th gear...but that should not have anything to do with the clutch dropping out. Subscribed!
Sounds like a clutch master/slave cylinder problem.. Not normal, but of course if it is working fine now most likely a "cannot replicate" problem.. In my experience, they usually get worse. Just be careful, as sometimes when they are going bad they will "bleed" off when you have it in gear (and clutch will engage). I always put tranny in neutral at a stop sign/signal so that you don't risk running into someone.
^ This. The only other thought I had was maybe your floor mat slid up and upon pressing the pedal down, it was forced under the mat and then held. Seriously though, that's almost 100% unlikely due to the weight of the clutch vs mat. You'd pretty much have to force that issue.
Surprising, is the fact you're still able to drive the car. It's almost as if air got into the system. Definitely have it inspected.
Is this normal?
Dylan,
Is this normal?
Dylan,
BREAKING-IN YOUR VEHICLE
Your vehicle requires a break-in period. Drive your new vehicle at least
100 miles (160 km) before performing extended wide open throttle
maneuvers and at least 1,000 miles (1,600 km) before performance/
competition conditions. Vary your speed frequently in order to give the
moving parts a chance to break in.100 miles (160 km) before performing extended wide open throttle
Definetly not normal.........could be a saftey issue so I'd see the dealer quick. On the other hand I wouldnt tell them you were at a race type event since it was your 4th pass.
Well its totally broke now. Went for a drive to see if it would stick to the floor again. First was fine........as soon as I hit second POP a loud noise and now second and fifth do not work.
This is my first Mustang..........I have had Vettes and BMW's for performance cars with no issues like this.
I still love the car but I am very dissapointed right now!
Dylan
Several Boss owners like myself have had this problem. It is a carry over problem from earlier Mustang GT's and the fix was suppose to be a different or added clutch pedal return spring. We have this updated pedal.
I reported this to my dealer's service dept and they contacted Ford engineering. Engineering told them to replace the pressure plate and with that also the clutch disc. At the same time I added a high flow clutch line. So far the problem had not returned but I can not say it is fixed for certain since the problem is intermittent. I have put several new track days on the car and it feels better after the fix and new line.
Sounds like you have a bigger problem now and your dealer should be able to help you out. For others with the problem Ford will fix it, they did mine. If you have a hard to work with dealer (I do not) then contact Daysha here on the forum and watch the magic happen
Dylan
We'll I left it with the dealer at 7am, they just called and said they will push for a new trans pressure plate and clutch. Waiting on Fords response now.
These shifting/clutch/trans issues just keep popping up. I had it happen last summer and it was a failed clutch. In my case the pedal stayed down and it wouldn't disengage. I was locked out of going into any gear. Once stopped with the car turned off I could shift the trans into first. I restarted the car and it surged forward even though the clutch was fully depressed so obviously the clutch wasn't disengaging. Once I got it to the dealer, we found a spring had been ripped from the clutch plate and lodged in between the pressure plate preventing it from releasing. My car currently shifts just fine even on the track, but there seem to be an unusually high number of incidents like yours. Hopefully they've found a fix and made a running change to the design.
I can certainly understand your disappointment. I keep thanking my lucky stars that I haven't had any issues so for but with more and more reported issues I'm beginning to think I'm on borrowed time.
You'll most likely get those parts, considering the car is so new and your "racing" isn't what caused the failure anyway. Obviously, yours went further than the slave cylinder if it broke the transmission(and it seems that happened). There are always possibilities things will break at any time. The good thing is, yours broke under warranty.
The tech working on the car said he really thinks it needs a whole new trans but he has to have Ford's go ahead.
"Clutch on the Floor"
Hmm, Is that like "Pants on the Ground"?
Kidding aside, I know you must be disappointed, but as I've always told people, if there is defective part from the factory, you're likely going to find it within the first 30-days or so.
One puzzling thing though, I'm not sure how a transmission issue would be related to the clutch staying on the floor..
The clutch pedal staying on the floor would only happen if something messed up within the clutch/pressure plate assembly (as pictured in posts above), but the transmission itself
