2012-2013 BOSS 302
build number
Old Mar 16, 2011 | 06:58 PM
12C/OBoss's Avatar
Took delivery today #127!!!
Old Mar 16, 2011 | 07:14 PM
phytrpilot's Avatar
Congrats Andy! Now you can get rid of all the stress these forums have caused as well as problems discussed. Tell us how it drives.
Old Mar 16, 2011 | 07:50 PM
Nccstud's Avatar
Question, does it just say "#127" or "#127 out of ####"?
Old Mar 16, 2011 | 07:53 PM
12C/OBoss's Avatar
0127
Old Mar 16, 2011 | 08:00 PM
Nccstud's Avatar
thanks just curious is all
Old Mar 16, 2011 | 09:43 PM
proboss's Avatar
congrats - 0127 has a good sound to it doint you think
Old Mar 17, 2011 | 06:28 AM
StillIntense's Avatar
Any number sounds good on a Boss 302!
I will say that whomever gets car # 302 is a lucky son of a gun!
Old Mar 17, 2011 | 10:44 AM
Dean#4AI's Avatar
Would you want number 666?
Old Mar 18, 2011 | 05:07 AM
manOwar's Avatar
0069 or 1969 would be great!
Old Mar 18, 2011 | 07:40 AM
5 DOT 0's Avatar
I have a Q2 build so I should be close to 1969/1970. That would be cool but not as cool as 1 or 302.
Old Mar 18, 2011 | 08:23 AM
manOwar's Avatar
True and at the rate cars are being built and my Q1 VIN not being issued yet, I might be close 0690. However, I don't think we can go wrong with any number!
Old Mar 18, 2011 | 02:22 PM
That's for sure!
Old Mar 18, 2011 | 02:52 PM
Nccstud's Avatar
Agreed. If my number was the very last one built...I think I would "suffer" through it
Old Jul 6, 2011 | 08:00 AM
PTRocks's Avatar
I am reviving this thread because I would like to get additional info from those who have it. I would like to start tracking the commit numbers to put the cars into actual build sequence.
I have found the commit number on three places since I took delivery of my car. Everyone should still have access to one of these:
Driver's side rear quarter window: The large 4 digit number in the center of the sticker.
Driver's seat protective bag: A separate sticker with a 4 digit number, the VIN, the words: 'Commit #:', and a date and time stamp.
The passenger side differential tube: The number appears in a grey box at the upper right corner of the label.
See the pics below for examples.
If you can get the commit number, please post it along with your Boss/LS # in the Vehicle number thread.
Thanks!
Attached Thumbnails build number-p1010959small.jpg   build number-p1010978small.jpg   build number-p1020082.jpg
Old Jul 6, 2011 | 08:49 AM
5 DOT 0's Avatar
Chris, is this the same as the blend (or sequence) number? If not what is the blend number used for?
Old Jul 6, 2011 | 09:29 AM
PTRocks's Avatar
It is not the same number. There is a bit of an explanation at the top of this thread. 1FAFP90 knows how it works. He's explained it somewhere, I'm still trying to find that post.
EDIT: here you go.
Originally Posted by 1FAFP90
Mustangs are not built in vehicle identification number order. They are built in Commit number order. That commit number is not on your window sticker, but you may see some labels on parts of your car with the number. It's a four digit number that rolls over when it reaches it's maximum value.
The gaps in the Mustang commit numbers are the Mazdas being built along with the Mustangs.
To confuse things even further, the body shop, paint shop and trim line all have their own commit numbers.
AAI uses a commit number (Job number) to determine the order of the car on the line. These commit numbers are used by both Mazda6 and Mustangs. AAI uses at least three sets of commit numbers - 1 for the body shop, 1 for paint, and the third for final trim.
Commit numbers can be assigned as close as a couple of hours prior to production.
Commit numbers are four digits so once they reach their highest value, it starts over at the lowest number.
This commit number does not appear on the Window Sticker, but you will see it on labels attached to various components of the car.
Basically, the Blend number 'should' be the order, but isn't because the factory needs to make last-minute scheduling decisions. Presumably if a supplier's truck gets a flat or a butterfly flaps its wings and the parts don't show up, or if the plant manager gets a call "we need this car, now!" kind of a thing.
The VIN's aren't assigned to the bodies until after the paint shop, so it's possible to insert or delete a build up until that time. This is where the Commit # comes in.
Old Jul 6, 2011 | 08:07 PM
Dean#4AI's Avatar
Thanks!
Well, I don't seem to have any of these. The quarter window sticker is gone due to the tinted windows and the dealership threw away the seat protective bag.
I crawled under the car to look at the axle and I don't have the sticker with the commit number on it. I have the sticker that goes completely around the axle but not the other one.
Old Jul 7, 2011 | 11:15 PM
Ford Man's Avatar
2916 car 0013
Old Jul 8, 2011 | 09:01 PM
2012YellowBoss's Avatar
2802 Boss 0006 2/15 build date
Old Jul 9, 2011 | 12:38 AM
  #40
Motor220122's Avatar
3405 maybe. #0030.
I found a shot the day I picked up the car but the number is reverse. Tough to see.
Not sure if these dates from the window sticker have anything to do with build date.
