Build Dates
Build Dates
Build dates are all over the place here so it hard to keep track. After the AAI shut down the earliest dates I saw were Feb 7 (or the week of). I did see at least one of those was pushed into the week of the 14TH. Anyone still have a date for next week of Feb 7?
I am 00572 and Feb 14 what is yours?
I committed to a car the dealer had already ordered. He told me it was originally a 1/31 build week that had slipped to 2/14, then to 2/28. If you assume a 3 week+ slip, then the first week will be 1/18+3weeks or 2/7 at the earliest; more likely 2/14.
That is what I am thinking, I was Jan 18, the second day of production (I think). Now it is Feb. 14. If they took the whole line and just moved dates it would make sense that Feb 14 is day 1 of production. Trying to confirm that or are they building this week.
I would like to know if anyone still has a build week of the 7th but would like to see dates for all 1st quarters.
At any rate, they should start SOON!
Here is a window sticker on a 2012 mustang with VIN 822
http://services.forddirect.fordvehic...BP8AM9C5200822
I have been checking with this but read that this site is not working with the 12's
http://fordlabels.webview.biz/webvie...5200572&ref=VL
In any case my sticker does not come up yet. Anyone getting their sticker yet?
Your build date is Feb 18th (the day production STARTS), your sticker will show up about a week before.
I have been curious if they are building the 12's this week, meaning the plant is working. By what Sparky said looks to be the case and the window sticker from AFM shows that also.
Sparky, what does the build date mean? If I have Feb 14 to the day, is that the date it starts the line or the date it is expected to finish? 14th is a monday, I assume that is start date since cars had Jan 17 which was suppose to be day one of 2012's.
The order gets scheduled to "week of" as a ballpark figure. This is based one the system assuming "x number of cars per day" times "y number days of production the plant is running". If there is a production delay (engineering issues, part supply, weather, machinery breakdown, etc) that date will get pushed back a week at a time.
When it gets closer to that week, they figure (using the same x/y numbers) what day that week the car should be built. Of course this is subject to the same conditions above that could delay things.
Atleast U have a build date. This is my response from ford:
Originally Posted by FordCustomerService
Hi Jason,
Thanks for the info. I was able to check your 2012 BOSS 302 order. It is showing as “Unscheduled-Material Hold”. This means the order is on-hold pending resolution of a production hold for material availability. No further info at this time. Please keep checking with me for updates.
Deysha
Deysha
