Broken Driveshaft
Has anyone broken the factory driveshaft or does anyone have info on the 2011 or new Mustangs breaking them?
Im fully aware of the V6 breaking them when they exceed the factory speed limiter. But the only ones I believe im came across were Mustangs with power adders. |
Bump:dunno:
never seen a GT ds brake.. but i'm sure it's happened :dunno:
edit: do u mean just from high speed? / stock motor ________________ |
Sticky tires----- broken driveshaft very common drag racing.... There not designed for that so dig into your pockets if u play
Originally Posted by Resolution78
(Post 6444016)
http://www.youtube.com/embed/syTPrD3YQs8 |
Nice launch. :nice:
also an aluminum driveshaft = big weight reduction in your driveline
Also, alum. DS = more smoothness in your drivetrain, no more clunking because of intermediate u-joints, and a tiny increase in your MPG due to a reduction in parasitic loss. At ~700$ it's not cheap, but I can tell you that I have 2500 miles with mine installed after 1700 with the OEM shaft, I really think it was worth the cost.
When people are willing to spend the same money on a Borla exhaust for better sound and a few HP, the same consideration should be given for a driveshaft upgrade. |
Originally Posted by ace72ace
(Post 6444304)
i've been wondering about these driveshafts. I think the Shelby comes with an aluminum one?
If one is going to replace the stick Boss shaft with aluminum does the Ford part fit or is there one brand recommended over some others? Are the aluminum shafts more prone to snappping at the drag strip? thanks |
No increase in NVH at all, as I said, it adds to the smoothness. I wish I could say like a 40yr old scotch, but I don't drink the stuff... ;)
I did get an increase in NVH with my MGW shifter because all that slop and vagueness you get in the OEM shifter is there to reduce NVH for the masses. Ford does this for a reason, and I don't fault them one bit for doing so, they are in business to turn a profit and crank out 60+ % of 6cy Mustangs to pay the bills and allow the Boss and GT500 buyers to have an option for such a fine automobile. I'm not one to have a huge sig with all my mods, etc, but I have a '13 Boss 302, with MGW/heat shield, DriveShaftShop alum ds, Goodridge SS brake lines with ATE Blue fluid, GT500 mufflers, etc. I drive this as a daily driver until the New England winter forces me to put it in the garage. This has to be a tough mod for most to consider as it's hidden under the car and hard to quantify. You have to drive another car w/o it to really detect a discernible difference between the 2. And without ever having tried one, it's really a case of you don't know what you are missing... I'm happy with my choice, I hope others can make an informed decision based upon real world owner feedback. I'm not pimping the DSS shaft either, you can get an alum DS from other vendors too, but I'm sold on the marketing hype on the DSS site. Put me down as a happy camper. :D |
(Post 6444340)
I did get an increase in NVH with my MGW shifter because all that slop and vagueness you get in the OEM shifter is there to reduce NVH for the masses. Ford does this for a reason, and I don't fault them one bit for doing so, they are in business to turn a profit and crank out 60+ % of 6cy Mustangs to pay the bills and allow the Boss and GT500 buyers to have an option for such a fine automobile. I'm not one to have a huge sig with all my mods, etc, but I have a '13 Boss 302, with MGW/heat shield, DriveShaftShop alum ds, Goodridge SS brake lines with ATE Blue fluid, GT500 mufflers, etc. I drive this as a daily driver until the New England winter forces me to put it in the garage. This has to be a tough mod for most to consider as it's hidden under the car and hard to quantify. You have to drive another car w/o it to really detect a discernible difference between the 2. And without ever having tried one, it's really a case of you don't know what you are missing... I'm happy with my choice, I hope others can make an informed decision based upon real world owner feedback. I'm not pimping the DSS shaft either, you can get an alum DS from other vendors too, but I'm sold on the marketing hype on the DSS site. Put me down as a happy camper. :D What else is needed besides the driveshaft when switching over? How is the install - seems like it would be relatively straightforward |
Put in a safety loop and run it until you need one. Chances are the stock one won't break.
Not all driveshafts are equal. You want one with a CV joint at one end [DSS, PST] all the rest are outdated and should retire.
Originally Posted by 908ssp
(Post 6444344)
I don't have a cv at one end on mine.... No noise or vibration issues .... Fronts
Driveshaft shop.... Ordered threw Dez racing I also have the MGW shifter it's awesome .... Installation. Is pretty simple and quick very straight forward no tricks .... One day I'll get a Drive shaft loop ..... Should have had one already running 11.4 |
Originally Posted by Twins
(Post 6444342)
thanks Ace. I have an MGW waiting to be put in now so I'll expect some differences in vibration.
What else is needed besides the driveshaft when switching over? How is the install - seems like it would be relatively straightforward http://bossmustangsonline.com/boss-h...r-heat-shield/ |
I have a steed aluminum one piece ds installed on my car. I dont drag race my car but it is a lot lighter than stock. Also the decel on the car is a lot less when you get off the gas, and less stress on your drive train. I would recommend it, it drives great and feels great. Personally one of my favorite upgrades.
http://www.steeda.com/store/steeda-m...iveshafts.html |
I installed a Alum drivshaft on my 04 Mach1 and didn't feel any improvement.
But I might do this for safety sake. |
(Post 6444397)
Waiting to be put in? You can do it yourself, and put that money spent on labor towards a new shaft. All you would need for specialty tools is a good strap wrench, socket extensions, 6pt deep sockets, and some ramps/jack stands. If you don't have the tools or are living in an apartment / condo I understand, but if you have any friends or relatives with the space and tools you can do it yourself.
http://bossmustangsonline.com/boss-h...r-heat-shield/ I know I know. Swamped here with crap. I'm trying to find a few peaceful minutes to put it in. There is a shop down the road that put in a shifter for a neighbor for $50!!! at that price I probably would let them do it although I would rather do it myself. |
