2012-2013 BOSS 302
Brake System Maintenance question??
Old Nov 25, 2011 | 09:02 AM
ulev1st's Avatar
Has anybody here ever used or have experience with MOTIVE PRODUCTS Power Bleeders for brakes? I was looking at their stuff and it seems like it might be a good deal to to some at the track "one man operation" brake bleeding...opinions please..
http://store.motiveproducts.com/ford...-0107-p38.aspx
Don
Old Nov 25, 2011 | 09:12 AM
zwede's Avatar
They work great. I've used one for years. I did have a problem with the hose cracking after a few years spraying brake fluid around. Recommend you replace the clear plastic hose they supply with a high quality rubber hose. I used transmission fluid hose and it has held up.
Old Nov 25, 2011 | 10:05 AM
Dean#4AI's Avatar
I've used one for quite a few years also. Great product and easy to use.
Old Nov 25, 2011 | 05:57 PM
OLOABoss's Avatar
Great product just make sure you get the right adaptor for the Ford. Big hint, do not put brake fluid in the Motive bleeder, just use it to pressurize the Master Cyl. Disconnect and add fluid to the master cyl, as necessary. Much neater and no need to clean the Motive and throw away excess fluid.
Peter
Old Nov 26, 2011 | 06:40 AM
Dean#4AI's Avatar
Peter
Why would you throw away excess fluid?
Old Nov 26, 2011 | 08:49 AM
PTRocks's Avatar
This is not the best setup. While it is convenient, using pressure to bleed the brakes adds moisture from the pressurized air into the brake fluid, degrading its performance. The best system is one that uses vacuum to draw the fluid from the caliper end.
Old Nov 26, 2011 | 08:50 AM
PTRocks's Avatar
I presume the assumption is the excess fluid has absorbed moisture.
Old Nov 26, 2011 | 11:11 AM
Dean#4AI's Avatar
So anytime you open a new bottle of fluid, you have to throw the rest away?
Old Nov 26, 2011 | 06:28 PM
2012YellowBoss's Avatar
Depending how much is left in it (fuller the better) you can store it for a short period. I will sometimes do this, I close the original can put it in a plastic bag and store it inside for a quick caliper flush after a track day or two. After a month or two I would throw it out. If you happen to leave it sitting with the cap off for a few hours, chuck it.
Old Nov 26, 2011 | 07:10 PM
Fat Boss's Avatar
If you suck most of the fluid out of the reservoir with a mighty vac to begin with, you can use the Motive catch bottle to catch every bit of the rest you flush out.
Mmmmmmm Blue.
Jim74656
May 1, 2023 02:15 AM
BavarianStang
Sep 5, 2015 05:55 AM
Sep 2, 2015 07:33 PM
