2012-2013 BOSS 302
Boss 302 on the dyno - 416 rwhp
Old 2/25/11 | 08:40 PM
fastautos's Avatar
Inside Line already put a Boss 302 Laguna Seca on the dyno and it made 416 rwhp:
http://www.youtube.com/watch?v=XonbZwYcIM0
Unfortunately they didn't do a comparison with the regular and TracKey
Old 2/25/11 | 08:46 PM
xlover's Avatar
at the very end if you listen close it sounds kinda cammed maybe they used the trackkey
Old 2/25/11 | 10:18 PM
06GT's Avatar
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
Sounds like the track key from the choppy idle just before they hook up the tow straps
I AM PLEASED
Old 2/25/11 | 10:28 PM
cobrasteve's Avatar
Very nice. Of course, the next thought that pops into my head; cold air, exhaust, tuned GT's are making around these same numbers.
What is the Boss really capable of?
Old 2/25/11 | 10:37 PM
12C/OBoss's Avatar
My best benchracing says with headers, o/r cat delete/ aftermaket tune/ and intake these things should be 455-475 whp and over 510 at the motor!! Forged internals and 8,000 RPM anyone??
Old 2/25/11 | 11:00 PM
06GT's Avatar
I agree, with the exception of the 8000 RPM thing. Many threads have said there is simply no PCM programming past 7800.
But yes, with some light mods this thing should put down even more power.
I'm gonna (try to) leave the powertrain alone until the warranty's up, though. Maybe.
Old 2/25/11 | 11:03 PM
Kaiserserser's Avatar
For reference, the standard gt put down 395 hp and 365 tq on inside line's dyno.
So looks like the Boss puts down 10 less ft/lbs and 31 more hp. Considering x% drivetrain losses, I guess it's surprising that both numbers are so close to the power differences ford quotes at the flywheel. Does that mean the Boss gains more HP and loses more TQ than ford says(compared to the GT)?
Old 2/25/11 | 11:29 PM
phytrpilot's Avatar
What you state may be true. But at the speeds it will run flawlessly there is no more need for added torque with an engine that "pulls like a freight train".
Old 2/26/11 | 04:58 AM
1 COBRA's Avatar
http://www.youtube.com/watch?v=t-H8z...feature=relmfu
Old 2/26/11 | 05:04 AM
Jza1736's Avatar
I love that line!
Old 2/26/11 | 07:49 AM
MustangFanatic's Avatar
Very nice - assuming a 10% driveline loss that means the Boss is making 457 HP at the flywheel - assuming a 15% loss, the flywheel HP jumps to 478. Either way, the Boss is definitely making more HP that advertised which is awesome. Ford has also stated that the Track Key tune doesn't increase peak HP.
Agree with others, there is more potential in this engine. Just a few short years ago, it would have taken some form of forced induction to make that kind of HP, very impressive.
Old 2/26/11 | 09:23 AM
MJockey's Avatar
My guess is Ford will not claim additional HP with the TracKey for legal reasons, but i guessing there is.
From Jeff Seaman, Mustang powertrain engineer:
"Are there any changes to the power delivery, such as the torque curve?
Absolutely. From an advertisement standpoint, we are not going to say that the TracKey gets you anything more than the base key. You’re welcome to go find out for yourself – it’s just the flip of a key. The low end torque is improved substantially, again making tradeoffs for basic drivability in order to deliver performance at all cost."
I like to see what Livernois can do with this car. That said I'll probably keep mine engine stock until the warranty is over.
Old 2/26/11 | 09:53 AM
cobrasteve's Avatar
I live less than an hour away, hmmmm
Old 2/26/11 | 10:21 PM
Brawlin' Boss's Avatar
With manual trans and a live rear axle I have usually seen 10-12% considered for drivetrain loss. Putting it around 470 - 500. I tend to think it's closer to 475. Either way too close for comfort for GT500 owners Of course the BOSS has a decent weight advantage.
Old 2/26/11 | 10:40 PM
fdjizm's Avatar
Wow, **** 5.0's!!
(oh come on that's sensored?)
It's the D word not the F word lmao
Old 2/27/11 | 09:06 AM
cloud9's Avatar
Just be careful which GT500 owners you tangle with..... Some have 50% more hp than the Boss and only 10% more weight
Old 2/27/11 | 09:53 PM
1FAFP90's Avatar
My math says 21 more hp. .... 416-395=21 ?
Old 2/27/11 | 10:06 PM
I probably shouldn't be allowed to do math or post on forums after 11... I may have had my friend Jim Beam check my math on that one.
Old 2/28/11 | 11:30 AM
bpmurr's Avatar
I wouldn't trust Inside Line numbers. Everything they post is inflated.
Old 2/28/11 | 06:49 PM
06GT's Avatar
Here are the graphs and commentary from their testing:
By Josh Jacquot | February 27, 2011
We barely let the engine cool after the drive down from Monterey before rolling into MD Automotive in Westminster, California and strapping the 2012 Ford Mustang Boss 302 to its Dynojet chassis dyno.
Ford claims the Boss produces 444 hp at 7,500 rpm and 380 lb-ft of torque at 4,500 rpm -- a substantial horsepower gain over the stock 5.0 GT's 412 hp at 6,500 rpm and 390 lb-ft at 4,250 rpm. Ford reengineered just about every piece of the Boss 302's engine so the gain should be substantial. And it is.
A careful look at the Boss' power trace shows it making power all the way past redline. In fact, the fuel cut appears to be about 7,700 rpm -- an astonishing speed for a V8 this size. With coolant and oil temps stabilized, we saw three runs within five peak horsepower of one another. And when you're talking about 415 hp, that's pretty much dead consistent. The lines laid down right on top of each other.
But how big is the improvement relative to a 2011 Ford Mustang GT 5.0?
Big.
Ford claims a 32-hp difference between the peak output of these engines and we measured 36 hp. Perhaps more relevant is torque, which Ford claims to be 10 lb-ft lower in the Boss. Not according to our numbers. Sure, the torque peak comes 900 rpm later, but there are two more lb-ft to be had from the higher-revving engine. Of course, at 4,350 rpm, where the GT makes peak torque, the Boss trails by about 11 lb-ft.
What the data doesn't tell you is how transformational a 900-rpm increase in peak power is between these two engines. At the GT's power peak of 6,650 rpm, the Boss is alreay making 24 additional hp. And it continues over the next 900 rpm to pour on the coals and churn out another 12 hp.
Quick Reply: Boss 302 on the dyno - 416 rwhp
