2012-2013 BOSS 302
Best brake upgrade?
Old Jun 22, 2013 | 12:16 AM
Dayve's Avatar
Best brake upgrade?
Even if I do not track my Boss, I still want the most stopping power available. What would be a inexpensive upgrade? Fluid, hose, pads...
Dave
Old Jun 22, 2013 | 06:04 AM
kn7671's Avatar
There are many brakes kits available, but other than the Ford Racing Parts kits, almost all of them are in the $2000-4000+ range. Since you didn't mention a price range, I'll start with some cost conscientious options.
The 2013/14 GT500 brakes, Ford Racing Parts M-2300-T, found around the web for around $1800. Unfortunately you wheel selection for fitment of the 15" Brembo 6-piston calipers is pretty limited, and you will likely have to measure many wheels to find out of they clear.
One of the better available are the Wilwood W6A WCCB Carbon-Ceramic Big Brake Front Brake Kit, $7,162.39. These are 14" 6-piston calipers with Carbon Ceramic rotors. These will be lighter than any stock steel rotor, and will be able to take repeated abuse without warping.
Old Jun 22, 2013 | 06:16 AM
Brandon302's Avatar
DOT 4 fluid, stainless lines, and I am really liking the HP+ pads for the street.
Old Jun 22, 2013 | 08:35 PM
Grant 302's Avatar
Ironically, the 'most stopping power available' on the street would come from upgraded TIRES.
Old Jun 22, 2013 | 09:50 PM
JPC's Avatar
JPC
Dave
low end cost side:
brake bleed and upgrade brake fluid
....would be surprised what a brake bleed does
Old Jun 23, 2013 | 06:02 AM
ace72ace's Avatar
Goodridge SS lines and ATE Blue fluid for starters, can't wait to replace the pads...
Old Jun 23, 2013 | 08:06 AM
orng302's Avatar
Is this your opinion, experience, or is there some documentation to support your statement? A change of tires is not an inexpensive option as you know.
Old Jun 23, 2013 | 08:39 AM
Tony Alonso's Avatar
I was just going to say the same thing.
Old Jun 23, 2013 | 08:57 AM
Having grippier tire leverages the available clamping force more effectively, especially in wet road conditions. It is the friction between the road and the tire that is key to a car slowing after the brakes are activated. Think about trying to stop on an icy surface. Having bigger brakes won't matter if the trip is slipping.
This, of course, assumes that you are properly managing the pedal force, the steering situation, and are aware of the traction situation on the road.
The stock brakes are going to be fine for street driving. High-speed driving and racing are much different. There, heat management is very important, so changes to resist overheating the braking system are crucial.
If it were my dime, I'd put my money first into tires if I wanted shorter stopping distances. I would then consider stainless steel brake lines to better modulate the pedal and a change of pad. Of course, changing the pads means you have to balance the trade-offs of dust, noise, pad longevity, and cost. I would do this for a STREET DRIVER, not a track car.
PS - This is an explanation of the basic physics. And this is a presentation on braking systems from an engineering standpoint.
Old Jun 23, 2013 | 10:05 AM
Grant 302's Avatar
^Tony, thanks for the explanation...that's exactly what I mean!
Not to be snarky, but yes, all of the above. Plus, it's conventional wisdom of the road race community...and like Tony points out, it's just the physics of all the parts involved with braking.
For the track, I care about upgraded brake parts for heat-sink, heat dissipation, fade resistance, temperature handling, bite, modulation, release...etc. Those factors don't matter much to me for the street. Cold braking performance will mainly come from the tires.
Old Jun 23, 2013 | 02:51 PM
orng302's Avatar
I understand the physics, and engineering behind better braking but my question was more about your inference that the stock Boss tires are inferior. Or am I misunderstanding your post? Btw, thanks for the explanation.
Old Jun 23, 2013 | 03:39 PM
Grant 302's Avatar
Probably just not making myself clear. I wouldn't classify the OEM P Zeros as 'inferior'...especially against most OEM selections. Pretty good in that regard. But they definitely have room to be improved on in the context of 'most stopping power available'.
In the wet, high silica compounds like Pilot Super Sports or Sport Comp 2's are way superior for braking (and handling). In the dry, there are many other DOT selections that will brake and handle better while costing less.
But my *main* point is that for the street, tires matter way more than the braking system upgrades.
Old Jun 23, 2013 | 04:56 PM
orng302's Avatar
Got it, thanks again.
Old Jun 27, 2013 | 10:22 PM
bob's Avatar
bob
Y'know the SS brake lines in combination with HPS+ pads make for an interesting situation with my car, the wheels will lock up briefly when you clamp down on the brakes if just for a fraction of a second.
Old Jun 28, 2013 | 06:14 AM
Fenderaddict2's Avatar
Mine do that stock. Thinking the pad change will be enough for me at this point.
Old Jun 28, 2013 | 09:27 AM
Brandon302's Avatar
I still believe the HP+'s to be a good upgrade, except the fact that they dust a lot. Our cars are loud enough that you shouldn't here the squeal and it shouldn't bother you if you do hear a little. They can get pretty interesting though once hot.
Old Jun 28, 2013 | 10:24 AM
ConeBoss's Avatar
HP+ is also a pretty noisy pad. Just to keep that in mind.
Old Jun 28, 2013 | 12:14 PM
Brandon302's Avatar
This is true, but I doubt you would hear it with the discs out or with anything above stock mufflers.
Old Jul 1, 2013 | 10:42 AM
ConeBoss's Avatar
I did, and I have no CATs. Those SOBs were squealing like pigs every traffic light stop. But they have great initial bite once you get a bit of heat into them.
Old Jul 1, 2013 | 05:36 PM
Brandon302's Avatar
What pads have HP+ bite without the sound though? I didn't think you could get good bite without the sound.
