Any body running harnesses in their boss??
Like the title says anybody running full on harness in their boss?? What kind? How does the bar mount? Do you like them? Do you regret it? I want these i think the recaros are begging for them. And itd be njce for track days to have them. Any info would be appreciated.
http://www.cooltechllc.com/Boss/Boss_Harness2Seat.shtml
and here is a thread about the install of the belts and the bar....
https://themustangsource.com/f813/co...k-peek-502918/
Yep... Cooltech harness and roll bar. And they are awesome! Check out their website...
Yes! There is also a rear shock tower brace. Check it out :
http://www.cooltechllc.com/Boss/Boss_Roll_Bar.shtml
I just installed the Cool Tech anchors and 6pt harness with a Corbeau harness bar this evening. I'm pretty happy with it. The only pain point is the upper factory belt points are a little fragile, ended up breaking a few small bits of plastic while tightening everything up.
This is just an awesome set-up. I will one day do this and the rear seat delete but until then I guess I will have to try and find the single bar set-up so I can still use the harness and the rear seats (kind of). Anyone know where I can get the bar that just goes across the rear seats behind the fronts?
If I were doing anything more than HPDEs in it, yes, I'd go full cage for the safety.
I don't claim it to be safer without a full cage. And you're right, if anything, it's less safe but I'm accepting the risk/reward trade off. You have to be in one serious accident on track to cause the kind of collision that would lead to the roof getting smashed in. Knock on wood, totally possible though.
