Vendor Showcase Forum for Vendors to display their products and specials
Strano Performance Hollow & Adjustable Swaybars: $379.99/set
Old Aug 17, 2010 | 01:54 PM
sam strano's Avatar
http://www.stranoparts.com/partdetai...D=80&ModelID=5
These are not your average swaybars, and you will not find another set of bars like mine.....
Some of the details:
Front bar is 1-3/8" (34.9mm). Rear bar is 7/8" (22mm).
*Both* the front and rear bars are 3-way adjustable. Most bar sets have an adjustable front, but a non-adjustable rear (there are some exceptions).
*Both* the front and rear bars are tubular/hollow for lighter weight. Most bar sets use either a hollow front and a solid rear, or solid bars at both ends which weigh over 20 pounds more for the set.
Strano Performance bars are direct fit for 2005+ Mustang Coupes. They bolt to the factory locations, no drilling, not cutting and no additional unsprung weight like you have with rear bars that bolt to the axle housing instead of the body.
We use high durometer (88 +/- 3 pts) urethane bushings.
Bars come with all new mounting hardware and bushings, grease too. And nuts and bolts where required.
Black Powdercoat
Fits with Fays2 and Steeda Watts linkages.
mx5jhb
Sep 30, 2015 04:44 PM
GeoWett
Sep 30, 2015 06:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
