Vendor Showcase Forum for Vendors to display their products and specials
💥NEW!💥 SS3 Fog Light Kit for the 2015-2017 Ford Mustang! | Diode Dynamics
Old Jun 24, 2021 | 01:16 PM
Diode Dynamics's Avatar
Former Vendor
Our SS3 LED Fog Light Kits are now available for the 2015-2017 Ford Mustang! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Functional Output: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. Making it a perfect option for your factory fog location! We offer these kits in two SAE-compliant optics:
  • Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
*When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
Sport/Pro/Max: Stage Series LED Pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The sport model uses high-intensity LEDs and is the best bang for your buck you’ll find. The Pro steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, both for high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2015-2017 Ford Mustang includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
Each kit will include:
  • Two (2) SS3 3” Round LED Pods
  • Two (2) H11 DT Adapters
  • Mounting brackets and hardware
Note: This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Old Jun 30, 2021 | 09:47 AM
Former Vendor
Our July 4th Sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our newly released SSC1 LED Pod, by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Old Jul 8, 2021 | 09:40 AM
Former Vendor
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our newly released SSC1 LED Pod! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Jul 14, 2021 | 03:45 PM
Former Vendor
In this video above, we compare our SS3 LED Fog Light Pods to other market-leading fog lamps! We break down each fog lamp by intensity, beam pattern, color temperature, and price.
For this comparison, we've used our state-of-the-art Goniophotometer, a device that measures multiple points to calculate the intensity and map out the beam pattern of each fog lamp! We've also used our integrating sphere, which is a device that is used to measure the color temperature of each fog lamp. We hope the data we collected helps you choose the best fog lamp for your vehicle.
John C.
Diode Dynamics
Old Aug 13, 2021 | 09:47 AM
Former Vendor
Check out this incredible output shot from Joey Olszowy rocking our SS3 Sport LED fog light kit in 6000K cool white!
Remember, all forum members are eligible for a free US shipping code. Just PM us!
John C.
Diode Dynamics
Old Sep 2, 2021 | 09:16 AM
Former Vendor
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our SS3 LED fog light kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
*Sale excludes preorders.*
Old Sep 7, 2021 | 10:23 AM
Former Vendor
Just a reminder! We just released our NEW Diode Dynamics flag shirt!
All orders over $300 during our Labor Day Sale will receive one free! If you're interested in purchasing a shirt, we have them listed under the gear section on our website.
John C.
Diode Dynamics
Old Sep 10, 2021 | 08:12 AM
Former Vendor
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Fog Light Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Oct 14, 2021 | 02:01 PM
Former Vendor
Our popular SS3 LED Pods are back in stock and ready to ship!
Plus, you can send us a direct message for free USPS standard economy shipping on all US orders!
Old Nov 11, 2021 | 03:06 PM
Former Vendor
Have you guys seen the Diode Dynamics product launch from SEMA 2021?
Due to high demand, SS3 LED pods will soon include a backlight feature!
6:03 - SS3 Backlit
If you have any questions, I'll be glad to help!
John C.
Diode Dynamics
Old Nov 19, 2021 | 10:29 AM
Former Vendor
SS3 Backlit is NOW AVAILABLE for pre-order!
The highest-intensity pod on the market is now available with an integrated amber backlight feature.
Click HERE to shop vehicle specific SS3 LED fog light kits!
Just a reminder, feel free to send us a PM for a free US shipping code.
John C.
Diode Dynamics
Old Nov 22, 2021 | 12:31 PM
Former Vendor
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our new Backlit SS3 LED fog light kits, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/30/2021.
Old Nov 30, 2021 | 09:30 AM
Former Vendor
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our new Backlit SS3 LED fog light kits, by entering coupon code "BF21" at checkout! Plus, get a free Diode Dynamics Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Old Jan 12, 2022 | 10:42 AM
Former Vendor
FREE CALENDAR ALERT!
For a limited time with every $300 purchase, we're throwing in our new 2022 Diode Calendar!
Plus, all forum US forum members are eligable for a free shipping promo code. Just PM us!
Old Jan 19, 2022 | 10:02 AM
Former Vendor
Our production team has just finished up testing our SS3 backlit LED fog light kits!
Pre-orders are NOW shipping.
If you have any questions, please feel free to let our team know!
Old Jan 25, 2022 | 09:35 AM
Former Vendor
"Are your SS3 LED pods are able to melt ice and snow built up?"
Yes, our SS3 Pro and SS3 Max power levels are able to melt snow and ice build-up!
Unfortunately, our SS3 Sport doesn't produce enough heat to melt snow and ice build-up.
Have questions regarding our Stage Series LED pods? Just let us know, we'll be happy to help!
Old Feb 16, 2022 | 01:17 PM
Former Vendor
Did you know?
Our team here at Diode Dynamics is an energetic group of over 80 people, who work hard to make quality lighting, with the best service possible in St.Louis, Missouri.
We take pride in our quality products, our customer-focused service, and our work in going "against the grain" to manufacture products here in the USA!
John C.
Diode Dynamics
Old Apr 13, 2022 | 10:42 AM
Former Vendor
For the month of April, we're throwing in a FREE Diode Flag Tee when you spend $300 or more.
Click HERE to shop your ride!
Old May 26, 2022 | 10:59 AM
Former Vendor
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
Old Jun 30, 2022 | 11:07 AM
Former Vendor
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
