Mustang Scott Drake LED Gauge Light Kit Installation Video 1979-1993
Former Vendor
Mustang Scott Drake LED Gauge Light Kit 1979-1993 | CJ Pony Parts
Scott Drake's LED Gauge Light Kit for 1979-1993 Mustangs and will transform your dim factory lights to ultra bright LED lights, which are three to four times brighter. This is a twelve bulb instrument panel kit and includes everything you need to brighten your dash area, including gauge illumination bulbs, turn signal indicator bulbs, warning lamp bulbs, and a high beam indicator bulb.
Begin your installation by removing the gauge cluster housing, steering column trim, and the lower trim panels. Once the gauge cluster is removed, you'll find the bulbs located on the back of it, each individually labeled.
Remove the old bulbs and replace with the new Scott Drake LED bulbs, and test to make sure all bulbs are working. Then return your cluster to your dash. Reinstall all the trim and panels, and your installation is finished in around an hour.
See more Mustang Dome Lights from CJ Pony Parts:
Mustang Dome Lights | CJ Pony Parts
See more Scott Drake Mustang Parts from CJ Pony Parts:
Scott Drake - Ford Mustang Parts - CJ Pony Parts
AMWill
7/20/15 08:40 AM
