FS: BRIGHT Reverse/Backup LED Bulbs! SMD and Hi-Power Models, Ships Same-Day
Supporting Vendor
FS: Mustang Reverse/Backup LED Bulbs! Plug and Play, Ships Same-Day
Ford Mustang Backup LEDs
Here's a great way to upgrade your Mustang's appearance and safety at night. These are great additions to any tail lights, and can be easily installed, plug-and-play. No resistors or anything needed. Perfect for Mustangs with backup cameras or dark window tint
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
HP36: Slightly higher brightness than OEM bulbs.
XP50: Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
The bulbs use an exact terminal and will fit as a replacement for stock incandescent All bulbs use less power and heat than the stock bulbs, and will last longer than your vehicle. Our LEDs use only the best components and are of the highest quality. The bulbs are designed for exceptional heat dispersion, and a diode is implanted to protect the LED from reverse polarity or voltage surge. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
1994-2004
2005-2012
XP50 Vs. Stock:
1994-2004
2005-2012
Any questions, feel free to ask via email (contact@diodedynamics.com), Post or shoot us a PM!
(314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Customer Submitted Photos:
That's cool but the '13-'14 models have the reverse lights built into the OEM LED tail lights.
Do you guys offer license plate bulbs for the '13-'14 models though?
I have one that's burnt out and am contemplating other options before I just put the OEM bulbs back in
Supporting Vendor
http://www.diodedynamics.com/store/l...late-leds.html
I have them in my 2007 GT and they give it a clean look at night. Big improvement over stock.
-Nick C.
We do offer license plate bulbs for 2013-2014 models:
-Nick C.
-Nick C.
SOLD!
$5 for shipping though?
Do you guys offer reverse LED's for a 2010 Focus?
nevermind, just found them.
Supporting Vendor
Thanks,
Paul
Supporting Vendor
The 194 style LEDs are usually the ones that stay lit when the car is off. It shouldn't happen with the Stage 2 Hi-Power LEDs.
Either way it's not going to draw enough electricity to drain your battery or cause any concern.
Let me know if you have any other questions or concerns,
Nick C.
Nick C.
Nick, I have WebElectric harnesses on the taillights of my '06 GT for sequencing. Are your taillight diodes compatible with aftermarket harnesses like that one?
Supporting Vendor
Thanks,
Nick C.
[QUOTE=Diode Dynamics;6661394]We will be testing it out soon on my 2007 GT, I have sequential tail lights as well. It will need load resistors, or hopefully we can just replace the flasher module with our LED one and the sequential taillights will function correctly.
I will make sure they take a video so I can show you the sweeping rate. Should turn out pretty awesome IMO.
How did this work out, Nick? Mine is the "06 with WebElectric sequentials installed. Will inline resistors do the trick, or will I need a different sequence module? Basically do I have to start form scratch?
Supporting Vendor
[QUOTE=Paris MkVI;6674316]
We did a Dodge Challenger with a webelectric sequential kit today!
All you have to do is splice in one resistor on each side and install the LEDs. It's super easy!
I'm still working on getting pictures and videos up on my car, but we have new cars coming in all the time and mine will be here so...I get pushed aside
Soon!
Nick C.
Soon!
Nick C.
Supporting Vendor
Just tried ya, probably gone for the day. I have an order in my cart with the July sale - free shipping still an offer for forum members? I'll pm you what I'd like to get...
Supporting Vendor
Give it another try at your earliest convenience and I'll get you taken care of: (314) 205-3033 ext. 206
Thanks!
Nick C.
