Vendor Showcase Forum for Vendors to display their products and specials
Dominate the Road & Track I YSR Coilovers for Mustang S650 at CARiD
Old Feb 12, 2025 | 01:16 AM
carid's Avatar
Supporting Vendor
The importance of high-quality suspension components can hardly be overstated. Nowadays, the market is flooded with suspension setups that promise to deliver customizable ride height and the long-desired perfect stance for your muscle car.
In this post, we’ll take a closer look at the Yellow Speed Racing Dynamic Pro Sport Coilovers made for your latest generation Mustang S650. This suspension system features 33-way adjustable dampening settings and full-length adjustment for precision ride feel tuning and excellent handling without sacrificing comfort.
Yellow Speed Racing® - 0.5"-2.5" x 0.5"-2.5" Dynamic Pro Sport™ Front and Rear Coilover Kit
Specifications:
  • Front Drop Height: 0.5"-2.5"
  • Rear Drop Height: 0.5"-2.5"
  • Front Coil Spring Rate: 7 kg/mm (392 lbs/in)
  • Rear Coil Spring Rate: 4 kg/mm (224 lbs/in)
  • Shock Absorber Internal Design: Monotube
  • Shock Absorber Type: Gas Charged
  • Shock Absorber Damping Type: Normal
  • Shock Absorber Adjustment Type: Single Adjustment
  • Shock Absorber Levels of Damping: 33 Levels
  • Shock Absorber Reservoir: Without External Reservoir
  • Front Shock Absorber Upper Mount Type: Aluminum Pillow Ball
  • Rear Shock Absorber Upper Mount Type: Aluminum Pillow Ball
  • Front Shock Absorber Camber Plate: Yes
Pillowball mounts and adjustable camber plates for both the front and rear are included to enhance steering response. Additionally, aluminum upper mounts with hardened rubber bushings help minimize noise and improve ride comfort.
All springs are made from high-quality SAE9254 steel, while the spring seats are forged aluminum for durability and rigidity. The shock body features an electroplated coating to prevent rust and corrosion.
For vehicles with a Double A-Arm suspension, this Coilover kit includes aluminum upper mounts as standard. Primarily designed for daily driving with occasional track use, this Coilover kit is easy to install using factory mounting points.
__________________
Ford Mustang http://www.carid.com/ford-mustang-accessories/
Call Toll Free: 800.505.3274 | Facebook | Twitter | YouTube
Old Feb 12, 2025 | 01:19 AM
carid's Avatar
Supporting Vendor
When it comes to performance, handling, and comfort, your suspension system plays a crucial role in how your Mustang responds, whether you're on the road, carving corners, or hitting the track.
Upgrade your Ford Mustang S650 with Yellow Speed Racing® Dynamic Pro Sport Coilovers and experience the perfect balance of performance and comfort. More options for your applications can be found here: https://www.carid.com/yellow-speed-racing/
__________________
Mustang259
Mar 5, 2013 01:03 PM
Nice Pony
V6 Performance Mods
Feb 12, 2013 05:25 PM
BlackMamba03
Aug 26, 2011 11:01 AM
SteedaGus
28
May 29, 2007 03:09 PM
TillmanSpeed
25
Feb 23, 2007 08:10 AM
