Vendor Showcase Forum for Vendors to display their products and specials
DEI/Ny-Trex Triple-Threat EFI wet nitrous oxide
Old Nov 18, 2010 | 07:38 AM
Xplosive Performance's Avatar
The next phase of nitrous injection for your ride.
These DEI Ny-Trex Triple-Threat EFI wet nitrous oxide systems combine all three valve functions--nitrous, fuel, and purge--in one easy-to-install component. The Triple-Threat valve features a billet aluminum machined body with three integral solenoid valves. The systems use a T-Rex nozzle with a true blend spray bowl that delivers a swirl cone plume at a 70 degree angle to the center of the throttle body for an even blend.
The systems also include:
* 10 lb. black powdercoated nitrous bottle with brackets
* Liquid-filled bottle pressure gauge, 0-1,500 psi
* Chrome 660 high-flow bottle valve with gauge port
* 15 A wide-open throttle activation switch
* Braided stainless steel nitrous and fuel pressure feed lines
* Dual taper jet kit
* Purge valve kit
* Fuel pressure safety switch, preset at 33 psi
* Electrical wiring, connectors, relays, and switches
* Mounting brackets and hardware
Product Description
The Triple-Threat is a precision machined billet Body with three integral solenoid valves with Volt-Trap coils for a dependable, clean, all-in-one nitrous system.
Ny-Trex nitrous systems use only the highest quality materials and components to produce the best looking, best performing and most reliable wet system around.
Ny-Trex exclusive Triple-Threat systems have been thoroughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
Exclusive Features:
Exclusive T-Rex Nozzle with true blend spray bowl delivers a swirl cone plume at a 70 degree angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering only 35 HP.
Solenoid Valves are made with Volt-Trap coils for stronger, more efficient power, allows for larger orifice, more flow and works with as few as 9 volts.
Plungers are made of of high grade stainless with greater tolerance to prevent sticking. The N20 seal is Teflon and a special Viton seal is used for fuel.
Dual Taper Jets provide a consistent slow of nitrous and fuel and come in a large array of sizes.
Easy Install Components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Teflon sealant and easy install Quick-Guide
Delivery StyleAir intake tubeNitrous System StyleWetMaximum Advertised Horsepower Increase150ActivationTPSJet Sizes Included (hp)50, 75, 100, 125, 150Dual StageNoBottle IncludedYesNitrous Bottle Capacity10 lbs.Bottle MaterialAluminumBottle ColorBlack powdercoatedBottle Brackets IncludedYesBottle Bracket MaterialStainless steelQuantitySold as a kit.
Call toll free 888.493.8041
PM us for additional savings over low our web price.
Use The Mustang Source as your promo code
Sep 8, 2015 10:45 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
JonathonK
Which is Better
Aug 30, 2015 06:14 AM
STOERKEL
Jul 30, 2015 07:30 AM
