Will the rims off a 2014 fit
ALSO ... Wheel Studs / Lug Nuts changed from 1/2-20 to 14MM for 2015.
So if you have aftermarket wheels that require different lug nuts, you will need to get a new set of metric lug nuts to fit your aftermarket wheels.
I have seen a few pics of 15's with earlier O.E. Ford Mustang wheels, so I'm guessing they just use the '15 lug nuts.
I'd be wanting to compare the wheel pilot diameters to make sure Ford did not change this to "metric" as well ... a smaller pilot would allow a larger pilot wheel to fit.
Doug
Doug
