Weld Marks in Trunk - Reason for Concern?
Greetings,
We found a weld mark in my wife's 2016 Mustang. We don't know much about welding, but one of our friends said it was because of damage. Is this something we could be concerned about? Attached are photos from both sides of the trunk.
Thank you in advance.
It looks a little sloppy. Can you take the same pic from further away. It's hard to get perspective on where that is in the trunk area.
Also, pull the weather stripping all around the trunk and see what the welds look like there. They should look smooth and clean. If you see burn marks or the metal looks damaged, the car has been in an accident.
What everyone else said...and, check your tail lights for alignment and fitment. If they are not perfectly aligned then it may have been in an accident. I would still have the dealer send it to the body shop to clean up and refinish the joints.
All they should paint is the area where the seams are. Shouldn't be too big a problem matching the paint in that small area.
Accident damage?? NOT!
I looked at mine and the welds look like this. Mine was ordered by me. built 12/10 and I picked it up from dealer 1/13. No damage and no repairs, maybe a welding machine out of adjustment but really good sealing job.
Here they are. Funny, I think it may be auto adhesive and not weld at all. A magnet will not stick to it and parts are a little soft.
All looks good. I actually think it might be automotive adhesive. A magnet will not stick to it and parts are a little soft. ??
Glad you put your mind at ease.
Ah. Yeah. That's what I thought it might be.
The join of the 'upper' trunk structure panel (under the glass) and the quarter panel structure.
It isn't gonna get all that wet except condensation maybe, so it's probably a few spot welds, but definitely seam sealer glopped over it... but that's a guess.
Feb 26, 2016 09:30 AM
