Sponsored by:
Sponsored by: CARiD
Ultimate performance pack thread
Old Jul 21, 2014 | 02:01 AM
Gogoggansgo's Avatar
Please make this a sticky
2010 3.73 axle package listed as Track Pack I highlights
-3.73 limited slip rear axle (carbon fiber clutch plates)
-Revised stability control (higher yaw threshold)
-Performance Friction "Z rated" pads front/ rear
2010 Mustang GT Track package II highlights:
- 19-inch Pirelli P Zer0 tires
- Front and Rear Stabilizer bars from Shelby GT500
- Anti-roll bars are bigger with the tubular 34mm front bar goes from 5.1 to 5.8 mm wall thickness and the solid rear bar increases from 20 to 24mm)
- Shocks which lower the car by 1/4 inch and Struts retuned for the springs
- Strut tower brace
- 3.73 limited slip rear gear with carbon fiber clutch plates
- Dual-Piston front brake calipers
- Performance Friction brake pads (front and rear)
- Rear trailing links with stiffer bushings
- ABS and AdvanceTrac retune
-Tire Mobility Kit Replaces Spare Tire
V6 Performance Package
-Choice of automatic or manual transmissions (coupe only)
-Strut-tower brace
-Larger front sway bar and SVT rear sway bar
-Unique front springs
-Unique front and rear calipers with performance friction pads
-19” painted aluminum wheels
-255/40-19 summer-only tires
-Unique stability control calibration
-Gloss black side mirrors
-3.31 limited-slip rear axle
Brembo Brake Package highlights :
-14" Brembo® Vented Rotors with Brembo® 4-Piston Calipers
-19 x 9.0-inch dark-stainless premium painted aluminum wheels
-255/40R19 Pirelli PZero Summer-Only (Coupe) or P255/40ZR19 Goodyear F1 -Supercar (Convertible)
-Different Springs (131lbs Front / 167lbs Rear)
-Different Struts/ Shocks (tuned for spring rates)
-GT-500 Rear Lower Control Arms ( Higher Durometer Rubber)
-Unique Electronic Stability Control® (ESC) Tuning
-Unique Sport Steering Control Setting (EPAS)
Track pack mustangs have all of the brembo brake package contents plus
-boss 302 oil cooler, M-6642-MB
-boss 302 radiator, M-8005-MBR
-boss 302 oil pan,M-6675-M50B
-boss 302 axle asembly with 3.73 M-4001-A373
-boss 302 torsen diff M-4204-MB
-boss 302 diff cooler M-4033-K
-boss 302 low expansion brake lines M-2078-MB
2015 ecoboost performance package
-larger rear sway bar
-heavy duty front springs
-unique chassis tuning
-unique tuning setup for the electronic power steering (EPAS)
-anti-lock braking (ABS)
-electronic stability control (ESC) systems
-4 piston brembo calipers
-unique 19 inch high gloss black aluminum wheels with 255 summer tire
-3.55 rear gear ratio
-larger radiator
-aluminum dash panel
-oil pressure gauge
-boost pressure gauge
2015 mustang gt performance pack
- Strut-tower Brace
- Larger Radiator
- Unique Chassis Tuning
- Upsized Rear Sway Bar
- Heavy-Duty Front Springs
- Gauge Pack (Oil Pressure & Vacuum)
- K-Brace
- BremboTM 6-Piston Front Brake Calipers with Larger Rotors
(Manual Trans Only)
- 19" X 9"(F) 19" X 9.5" (R) High Gloss Black Aluminum Wheel
- 255/40R19 (F) 275/40R19(R) Summer Only Tires
- Unique Stability Control, EPAS & ABS Tuning
- 3.73 TORSEN® Rear Axle
- Spoiler Delete
Note: Not Available with Automatic Trans (443), Spoiler Delete (13D), Spare Tire (66W) or 18” wheels (641).
Old Jul 21, 2014 | 06:13 AM
AWmustang's Avatar
2015 ecoboost performance pack is fastback or convertible and manual or auto.
2015 GT PP is manual fastback only.
Old Jul 21, 2014 | 10:12 AM
davesvt2000's Avatar
2010
Old Sep 10, 2014 | 07:38 PM
dswieson's Avatar
Anyone know why you can't get the GT PP option for the 2015 convertible? Or if it will become an option sometime later this year?
Old Sep 10, 2014 | 07:46 PM
pminri's Avatar
- Strut tower brace
-Strut-tower brace
-larger radiator
-oil pressure gauge
- Strut-tower Brace
- Larger Radiator
- K-Brace
(Manual Trans Only)
- Spoiler Delete
Are you sure about the low expansion brake lines on the track pack?
dblhelx
Oct 6, 2015 08:08 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
M3hunter
Sep 10, 2015 09:26 AM
Sep 8, 2015 10:45 AM
